VTEC spool solenoid & vtec pressure wires switched around ?
Old May 24, 2009 | 08:07 PM
Charlie Moua's Avatar
Default VTEC spool solenoid & vtec pressure wires switched around ?
gsr + P72 + skunk2 IM
Right now I have code 21 (vtec solenoid).
The CEL only comes on if I go past 5,100 rpms & no vtec. It does not go into LIMP MODE. After cutting off the car & restarting it, CEL is off until I go past 5,100 rpms again... and stays on until I cut off the engine.
I've done search and did oil change, checked to make sure the vtec solenoid "clicks", check for a dirty screen filter on the solenoid, .... and my last resort is that it may be wiring.
Q? wouldn't I have a CEL ALL THE TIME if i had these 2 wires switched around?
.... because if thats the case, then I know I do have it wired correctly.
Green/yellow wire is the VTEC spool solenoid, and the lower Blue/black is the pressure switch.
Old May 25, 2009 | 02:33 AM
b16_sol_707's Avatar
Default Re: VTEC spool solenoid & vtec pressure wires switched around ?
check the resistance (ohms) from the solenoid wire to the pin a4 on the ecu. if you get anything other than 0 it's a good wire.
Old May 26, 2009 | 11:42 PM
Basically your telling me to test to see if it's a closed/completed circut right?
So if I put one probe in the plug wire and the other probe to the 4 PIN and get "0" its bad and means I probably have my wires crossed right?
Old May 27, 2009 | 07:13 AM
92ehatch's Avatar
doesnt necessarily mean your wires are crossed. it just means that you dont have a connection between the pin and the plug.
so either the wire is crossed, or broken somewhere.
but either way, do what he said, if you get 0 or no reading then you have one of those two problems.
Old May 28, 2009 | 05:28 AM
92ehatch's Avatar
no it doesnt need to be on to test for continuity.
all that test is for, is to make sure the wire has a connection from point A to point B.
Old May 29, 2009 | 12:15 PM
found out the 2 wires were accidently switched around...
Vtec works fine now.
Charlie
EP-sLYD
Mar 5, 2007 05:29 PM
neophyte210
Oct 16, 2006 03:45 PM
SpoonEk253
21
Nov 20, 2005 04:11 PM
sharkcohen
Mar 11, 2005 07:55 AM
boosh
Jul 16, 2003 02:30 AM
