oil pump gasket
Old May 24, 2009 | 07:31 PM
EGR95's Avatar
Default oil pump gasket
does oil pump have a main gasket between block and oil pump. i called some people to see if oil pumps have gasket but they say that they dont need one or have one.
Old May 24, 2009 | 07:32 PM
rick_rabies's Avatar
I'm not Rick!
Default Re: oil pump gasket
use rtv glue
Old May 24, 2009 | 07:54 PM
EGR95's Avatar
so i have to use rtv glue.
Old May 24, 2009 | 09:42 PM
The_Honda_Guy's Avatar
Hondabond HT specifically is what they use for it. Also, you'll have to take the oil pan off to change the oil pump gasket along with quite a few other things, so make sure you have new seals and gaskets for those also.
Old May 24, 2009 | 09:48 PM
stevenDAtegra's Avatar
Honda bond works well for everything! I didn't have a oil pump pick up gasket(well at least I thought I didn't but found one later on) and used it for a gasket for the oil pick up.
Old May 25, 2009 | 10:27 AM
EGR95's Avatar
honda bond were can i buy it.
Old May 25, 2009 | 10:34 AM
kp's Avatar
kp
Old May 25, 2009 | 11:12 AM
EGR95's Avatar
so??
Old May 25, 2009 | 11:27 AM
92ehatch's Avatar
HONDA BOND IS FROM HONDA
buy it at HONDA
Old May 26, 2009 | 06:47 PM
EGR95's Avatar
ok
Nshouse0003
Jun 9, 2011 11:29 AM
Inextricabledrvr
May 15, 2009 08:03 PM
JLefevers
Jul 9, 2006 02:14 AM
O16581724 5 2 5
Jun 23, 2005 07:07 PM
