Compression test on a b20vtec?
Old May 24, 2009 | 02:20 PM
Japankid's Avatar
Default Compression test on a b20vtec?
what shode the Compression be on a b20b block stock with a b16a head ?
stock b20b with 8.8. cr psiton vs a b20 block with Type R replica piston
Old May 25, 2009 | 09:14 AM
Japankid's Avatar
Default Re: Compression test on a b20vtec?
over 35 Views no help
Old May 25, 2009 | 10:04 AM
triniskill's Avatar
give or take b20 with b16 head. compression should be around 9:1(someone correct me if i'm off) so your compression test should be around 180 give or take..
Old May 26, 2009 | 10:43 AM
Japankid's Avatar
so it shode be 180psi for the test
cr 9.1 what if its a gsr head ? the compression is not even that high will it make a good turbo or nos set up?
what if the block is built with piston ? type r reps
Old May 26, 2009 | 11:30 AM
redsolturbo's Avatar
stock b20z1 for me popped 210-220 psi a cylinder.
b20z1 with 11.8.1 ycp itr spec pistons popped near 250-260 psi a cylinder
both on a stock b16a head
that was on a snap-on compression tester, not some cheap as s$20 dollar made in china piece of crap. you get what you pay for in quality and durability when it comes to good tools.
dondajunk
Aug 27, 2014 09:57 AM
yolk
Jun 18, 2010 06:05 AM
Adam_b16a
Nov 30, 2009 08:29 AM
othick
Apr 2, 2003 04:32 PM
