wat motor oil are you using in your b20v?
Old May 24, 2009 | 10:32 AM
b20vdelsol619's Avatar
Default wat motor oil are you using in your b20v?
I heard 20w50 is good and people swear by 10w40 Wat are you using?
But other
Old May 24, 2009 | 10:52 AM
Ya Digg's Avatar
Default Re: wat motor oil are you using in your b20v?
wouldnt 5w 30 be best? unless there is something I dont know that makes them need thick oil
Old May 24, 2009 | 10:56 AM
TravisCadello's Avatar
10w30 depending on climate.
Old May 24, 2009 | 10:59 AM
I'm in sunny san diego
Old May 24, 2009 | 11:01 AM
In Hot weather above 90 F Id run 10w30 and under 90 F daily id run 5w30. it depends on where you live mainly.
Old May 24, 2009 | 11:02 AM
TOO MUCH TORQUE's Avatar
ow-30, you want run the lowest W for honda engines
20w-50 is OVERKILL
Old May 24, 2009 | 11:05 AM
I'm not sure. i just read about oils and they say its the Climate the engine oil will be running in that effects it. 10w30 is for Texas weather and is what i always ran in all my cars. if i run 5w30 in my civic i hear the valve ticks louder.
Old Mar 13, 2018 | 09:34 AM
Norelli96's Avatar
I run 15w40 Rotella in mine. I live on the coast in Mississippi where it stays hot so 15w40 is perfect for the weather and for the higher out out of the combination of the b20 block and vtec head. Absolutely do not run 0w30 thats only for new Honda’s. Depending on how cold it is where you arat 10-30 10-40 or 15-40. 20-50 is good with a turbo setup but no turbo no need
Old Mar 13, 2018 | 09:52 AM
Chance EG's Avatar
Check the topic dates before you comment on them, this was a 9 year bump.
10w30 always, 0w30 is acceptable in cold climates. I would not recommend 20w50 unless there are problems with oil pressure, and even then I would consider that an improper bandaid rather than a fix.
Old Mar 13, 2018 | 01:15 PM
tony_2018's Avatar
Fish Twig
From where? Did you confirm this?
Old Mar 14, 2018 | 11:26 AM
tommychong's Avatar
I’ve had several b20 Vtecs and built about 10 of them. They love 5w30 synthetic for daily driving and 10w30 synthetic for track use. Best oils for longevity. I use Valvoline.
silverbullet9626
Jul 4, 2009 11:02 AM
jacky599r
Dec 15, 2005 09:12 AM
Honda_Tengoku
Aug 29, 2004 06:15 AM
98lude-t
Apr 2, 2004 10:12 AM
turbosi92
Jul 3, 2002 11:27 AM
