HELP!!! Headlight alarm malfunction
Old May 23, 2009 | 11:03 PM
chemikalburn's Avatar
New User
Icon2 HELP!!! Headlight alarm malfunction
I have a 95 Honda Civic whose battery has died three times because I left the headlights on. The alarm that is supposed to sound when you leave the lights on and open the door is malfunctioning. However, the same alarm rings when I leave the keys in the ignition, and open the door, so it couldn't be the door switch....could it?! I checked the fuses, and didn't see any blown. I read the manual to find which fuse it would be and can't find it. If you know the fuse #, or what the problem might be, please let me know asap.
you should know that the car had previously been broken into and the windshield wiper stick was affected by this, in that it is so loose it sometimes falls down when going over a bump. Although this is on the other side of the steering column than the headlight stick, it could have been affected. not sure if this could be factor in my problem, it's only an fyi.
If you have any input, please please please help me out.
thank you
lawanyaccord
Jul 13, 2015 01:50 PM
chemikalburn
May 24, 2009 11:58 AM
Rizzen
Audio / Security / Video
Sep 21, 2008 01:35 PM
mingu
Oct 24, 2005 04:29 PM
