coolant leak
Old May 23, 2009 | 08:39 PM
gsr96cx's Avatar
Default coolant leak
This is weird. I just did a d16y8 motor swap into my 96 civic cx hb, and while driving I started to smell this coolant sent and started to hear a sizzing noise. I parked the car and started checking for anti freeze leakage under the hood but found none. So i started the car up again and heard nothing. Took it for a test drive and the smell, noise came back, but this time my car was overheating so i knew it had to be something with the coolant. I re-checked everything and still nothing under the hood. So i went and checked inside the car and I noticed a pile of coolant dripping from the center of my dash and right onto my pass. floor. Anyone know what could have caused this? Or how I can fix it?
Old May 23, 2009 | 08:43 PM
rick_rabies's Avatar
I'm not Rick!
Default Re: coolant leak
your heater core. it corrodes. at the firewall 2 hoses go into the heater core check it. id check inside the car too under the dash....meaning you have to take your heater stuff out. i took out my dash and took a sledge hammer to the heater stuff and threw it all away so i cant tell you how to take it out.
Old May 24, 2009 | 01:38 AM
aken's Avatar
New User
yea for sure its a heater core problem
like rick said you gotta take out the dash and remove the heater core,
if you leave it like this (like i did cause i didnt know what was going on), then prepare to have slimy greasy windows from inside the car, frequent refilling of the coolant,and over heating car, and a really disgusting lake of coolant on your pass side. good luck
Old May 24, 2009 | 06:57 AM
gsr96cx's Avatar
thanks for the information guys, I'm going to be checking it today.
Old May 24, 2009 | 06:58 AM
gsr96cx's Avatar
anymore information would also be great.
Old May 24, 2009 | 04:34 PM
gsr96cx's Avatar
bump, does anyone know what this can be? Or what can cause my coolant to look rough, sand like, but green still.?
Old May 24, 2009 | 08:12 PM
gsr96cx's Avatar
bump..
Old May 24, 2009 | 08:16 PM
R666_EK's Avatar
Nothin else to it. Your heater core is toast. Get yourself a case of beer and be ready to pull your dash apart.
Old May 24, 2009 | 09:45 PM
PhatFactory's Avatar
case of Heineken will do the trick and 2 packs of newports box. Good luck
Old May 24, 2009 | 09:47 PM
The_Honda_Guy's Avatar
Everyone already told you what it is. You need to pull the dash and remove the blend door box, then disassemble it and change out the heater core. This is the only way you'll get coolant inside the passenger compartment and is the problem you're having. If you need help pulling the dash pick up a Hayne's manual.
Old May 24, 2009 | 10:10 PM
R666_EK's Avatar
Good call.
Old May 25, 2009 | 07:08 PM
gsr96cx's Avatar
Thanks alot guys. I guess this will be a pain in the s. Its like $290 for a new heater core....The beers sounds good but after I buy a heater core I'll be broker then a can of mug pop...lol..Thanks again for the help though.
Kasheena Winn
Oct 28, 2017 03:21 PM
Captain_Fook
Jul 1, 2014 05:23 AM
meow27
Feb 3, 2014 06:31 AM
verbal assassins
Feb 12, 2007 10:42 PM
jvonb
Jan 10, 2006 03:30 AM
