Rear sway bar parts?
I have a 95 ex 2 dr that does not have a rear sway bar. i think this would be a great easy addition to my car and help keep the rear end planted a little bit better. i dont road race currently and i am not crazy about spending a lot of money on something like this. but i have been doing some research as to what i can use, and there seems to be alot of aftermarket options, as well as oem.
i am pretty sure I want to go with the oem, as it is guaranteed to fit, it is inexpensive, and if its not what i want i can always upgrade to something larger later on.
I just wanted to confirm what i need for this mod:
rear lower control arms from either a 92-95 4dr civic or a ?? year integra
sway bar from either 92-95 4dr civic or a ?? year integra
Sway bar brackets from 92-95 4dr civic or ?? year integra
So i just wanted to check, if this is all i need, and also, what year integra i could pull this from. i will most likely go with the integra bar and brackets since it is slightly larger.
If anyone knows this info, or has some better suggestions i am open to anything.
Re: Rear sway bar parts?
Rear LCAs from 92-95 Civic Sedan EX/94-01 Integra GSR/88-91 Integra
Sway bar from 94-01 GSR, it's bigger.
D-brackets from 92-95 Civic Sedan EX/94-01 Integra GSR (I would go with GSR)
There is a guy selling all these from a GSR in the For Sale section, his name is "qwk db8"
what are your spring rates rated at?
if youre running stiffer in the rear, which i doubt you are, but just in case if you are, and run a thick gsr, or thicker type r sway bar, then youre aiming straight towards some bad over steer.
Sorry to thread jack, but I can I use the rear lca from the 94-01 integra ls? I went to the junkyard and picked up a rear sway bar and endlinks, but realized they wouldn't bolt out without the rear lca when I tried to put them on. The reason I'm asking is cuz Rok Stok posted that you need the rear LCA from a gsr, 88-91 integra, or 92-95 ex sedan.
reysi1026
01-14-2010 01:45 PM
JDMCRX
12
10-17-2008 08:46 AM
