car wont star weird problem
Old May 23, 2009 | 07:09 PM
mony725's Avatar
Icon2 car wont star weird problem
alright here it goes the other night im driving around and right from the start i felt something weird it would start to sputter a little and kept getting worst i come to a red light it sputtered hard and died i start back up after a couple of trys and it just sputtered really hard and died agian and havent got it started since heres a list of what i have tryed
i have a ls boosted in a 98 civic
new plugs (ngk v-power)
new wires
new main relay
switched ecu between obd2/virgin obd1/obd1 with hondata
put my dizzy in my friends car ran fine
took out the whole engine harnes and looked for cuts or broken wires everything was fine
checked all the fuse
im getting fuel
****im gettin spark but weak i thnk
have three ground and ground on the thermostat from the harness all connected
im stumped one thing i havent tryed is checked compression dont i cant think why it would sputter and the things that happened that that has any thing to do with compression
let me know what you think this is killing me i have no clue
thanks in advance
Old May 23, 2009 | 07:10 PM
mony725's Avatar
Default Re: car wont star weird problem
i forgot to say i changed the icav too
Old May 23, 2009 | 08:22 PM
vlc92189's Avatar
did you ever just try the ignition coil?
Old May 23, 2009 | 08:23 PM
vlc92189's Avatar
nevermind, you used a good dizzy.
Old May 24, 2009 | 04:28 AM
mony725's Avatar
bump
someone has to know whats goin on
Old May 24, 2009 | 05:17 AM
civic_driver's Avatar
Measure resistance on the spark plug wires and it has to be less than 25K Ohms. Make sure the spark plugs have the correct gap 0.043" I think it is. Next, take a compression test and see if there are any problems there. Also, check your turbo for problems such as oil and coolant getting to and from the turbo. Make sure the turbo is spinning right and there's no freeplay in the shaft.
Old May 24, 2009 | 05:58 AM
mony725's Avatar
the spark from the dizzy is weak but i put it in my friends car and it ran mint the plugs are all gaped at 0.043 like you said and the turbo is mint i dont have a compression tester do you really think it could be that becuase why would it sputter and stuff if it was compression
Old May 24, 2009 | 06:04 AM
mony725's Avatar
ive checked everything twice that i listed this is killing me could it be a head gasket or something internal????
Old May 24, 2009 | 06:45 AM
Former User's Avatar
The timing belt may have skipped a tooth or two.
Old May 24, 2009 | 08:42 AM
mony725's Avatar
nope timing is perfect
Old May 24, 2009 | 08:55 AM
callmechad's Avatar
so im assuming you checked your rotor, it spins when you try to turn the car over
Old May 24, 2009 | 09:02 AM
mony725's Avatar
no i havent checked that but if it worked in my friends car why wouldnt it work in mine
Old May 24, 2009 | 09:07 AM
mony725's Avatar
yea i just checked it
it spins the end of the rotor has a little bit of burn on it but that must be normal from spark no??
Old May 24, 2009 | 09:13 AM
Slopoke's Avatar
You said you are getting fuel. Where are you checking it at?
Are you just listening for the fuel pump to prime? Did you check for pressure at the fuel rail? Are your injectors actually firing?
Old May 24, 2009 | 09:19 AM
mony725's Avatar
there is presure in the rail and i have rc 550 injectors and stock ls injectors tried both of them
Old May 24, 2009 | 09:20 AM
mony725's Avatar
the only thing i can think of is the dizzy becuase it has weak spark but i put in a new coil and tested it on my friends car
Old May 24, 2009 | 09:21 AM
Slopoke's Avatar
Go back to the basics.
Air, fuel, spark, timing, compression.
If there is one you havent checked, check it.
Old May 24, 2009 | 09:22 AM
mony725's Avatar
comprssion i havent checked but y could i be getttin weak spark
Old May 24, 2009 | 09:28 AM
Slopoke's Avatar
How do you know it is weak?
It doesnt take much spark to get a car to idle. I've seen some nasty, greasy, half melted plugs still put off enough spark to start a car.
Old May 24, 2009 | 09:30 AM
callmechad's Avatar
you said it was burnt? how bad?
Old May 24, 2009 | 09:31 AM
mony725's Avatar
i guess i lokked at it and it would spark but it seemed slow and not that much i mean your probably right i dont really know what the spark should look like but i was just gues i gotta go grab a compression tester
Old May 24, 2009 | 09:38 AM
mony725's Avatar
a little bit its brown and itts suppose to be yellow it only the edge were it sparks off to the wires in the cap
Old May 24, 2009 | 10:24 AM
mony725's Avatar
ok just checked compession 180 across all 4 but i have a little of anifreeze on my plugs?????
Old May 24, 2009 | 10:37 AM
mony725's Avatar
come on someone i need help there
Old May 24, 2009 | 11:22 AM
Ok, it's time to check the TP, MAP and IAT sensors for correct resistance/voltages.
95vr6man
19
Sep 12, 2006 11:09 AM
stp_vtec_boi
Aug 23, 2006 09:06 PM
xerox445
16
Jan 28, 2005 09:10 PM
Honda Sport
Jun 4, 2003 05:27 PM
