99 civic code P0131
Old May 23, 2009 | 04:27 PM
coryfenton's Avatar
Default 99 civic code P0131
Hey guys, I'm throwin a damn CEL again! well I just finished up the swap to a B16A2 SI motor and last week I was throwing code P0135 some o2 wiring malfunction... Well I got that all fixed up and the next day I threw code P0131 and it says something like heat malfunction code... I have been re searching allover online and everyone has said its a very difficult code to get rid of... Have any of you guys had they same problem or know anything about this code?? Sorry if the post is hard to read I am on my phone thanks for any help tho guys.
Old May 23, 2009 | 07:29 PM
coryfenton's Avatar
Default Re: 99 civic code P0131
TTT.
and i also forgot to mention that I have an exhaust leak from where the headers meet the cat...
would this cause an o2 malfunction code at all??
Old May 23, 2009 | 08:45 PM
rick_rabies's Avatar
I'm not Rick!
yeah, fix it and let us know what changes.
Old May 23, 2009 | 10:41 PM
coryfenton's Avatar
so the leak would cause a malfunction?
Old May 11, 2010 | 06:04 PM
civicboi512's Avatar
mine thru the same code on me after i did my b18c swap in my 99 and yes the leak between the header and the cat will make the code come up but make sure also you check the o2 sensor clip to make sure its not loose and make sure the o2 sensor is tight and it should go away i havent had mine pop back up for over a year and still going
GruvyTune
Nov 4, 2003 07:42 PM
B18C1 '96 Coupe
Jul 2, 2003 08:43 AM
RiceNmotioN
Mar 26, 2003 03:17 PM
S13 slide
Dec 1, 2002 06:44 AM
