Code 23 and 43. going on vacation need help asap
Old May 23, 2009 | 08:02 AM
jonathan13's Avatar
Default Code 23 and 43. going on vacation need help asap
as the title says my car starts throwing codes 23 and 43 after just a few minutes of driving- never on startup and even on warm starts.
23 is obviously the knock but i know its not knocking so im going to check the wiring for that. hoping maybe its related and if i fix one it will fix the other.
43 is the fuel supply system which has my clueless because it isnt running bad at all- runs very well actually.
Ive had a problem with one of my o2 sensor wires coming loose but in the past it has just thrown the o2 code when this has happened. could this be the reason for my code 43? could a code 43 set off the knock somehow?
any help would be GREATLY appreciated because im supposed to leave on vacation in about 12 hours.
Old May 23, 2009 | 10:16 AM
jonathan13's Avatar
Default Re: Code 23 and 43. going on vacation need help asap
knock sensor was unplugged. both codes are gone
Old May 23, 2009 | 11:08 AM
z6hatchboy's Avatar
thanks for posting your finding!
Old May 25, 2009 | 08:02 AM
jonathan13's Avatar
no problem at all.. i always try to post the solution whether i found it on here or not in case someone else has the same problem down the road
Old May 27, 2009 | 06:13 PM
G-Auto*Hero's Avatar
im getting to code 27 and i was just woundering were you guys look them up?
hondaaccordf23
Oct 25, 2012 03:54 PM
LS_VTECteggy
Jul 5, 2010 07:57 PM
lsvtec2000
Feb 23, 2009 05:23 PM
TealEG!
Jun 4, 2006 02:04 PM
CRXSIFUEL
Jan 12, 2003 05:13 PM
