98 LS Keyless Entry
go to ebay and search for one and u can program it urself. http://www.keyless-remotes.com/-strs...Categories.bok
Here are the instructions
1) Unlock Doors
2) Turn ignition key to "ON" position (II)
3) Press the "LOCK" or "UNLOCK" button on the remote
4) Turn the ignition key to the "OFF" position (0, I)
5) Turn the ignition key to the "ON" position
6) Press lock or unlock
7) Turn key to off position
8) on position
9) lock or unlock
10) off position
11) on position
12)lock or unlock - doors should cycle to indicate successful programming. If you only have one remote, turn ignition to off or don't touch anything. if you have 2+ remotes, go to 13:
13) lock on each transmitter that you need to program
*Steps 2-12 must be performed within 5 seconds of each other. Step 13 can be performed within 10 seconds of step 12. If it doesn't work, give me a yell
1) Unlock Doors
8) on position
9) lock or unlock
10) off position
11) on position
is that how it can stock with a keyless entry from the dealer if not the dealer wont have it and i dont think the LS or any integra come like that stock but correct me if im wrong
Also, is there anyway to know ahead of time if the car actually has keyless entry? I called the dealer and they said it was an accessory option, and there is now way to tell if it actually has it.
Do a search. There should be a little control box either under your drivers seat or under the dash somewhere.
Sorry I thought it was standard so I assumed my car had it until I called the dealer.
Yeah, it's pretty shitty that most civics (96-00) came stock with the keyless control built into the head unit. All they have to do is buy a $25 remote on ebay and it's done. Unfortunately on integra's you have to buy a bunch of crap to get OEM keyless.
