White corrosion on exhaust valves
Old May 22, 2009 | 12:48 PM
eg:R's Avatar
Default White corrosion on exhaust valves
anyone know what can cause this? leaking coolant to cylinders or lean?? will seafoam clean this?
Old May 23, 2009 | 10:20 AM
eg:R's Avatar
Default Re: White corrosion on exhaust valves
anyone
Old May 23, 2009 | 06:10 PM
marcj's Avatar
was the car smoking when it ran?
I rebuilt a d16 head that had burnt white matter on the valves in one cylinder that I could scratch off with steel wool. after removing them I found oil built up behind them. I'm sure it's the same.. bad valve seals
Old May 24, 2009 | 01:05 AM
eg:R's Avatar
yes the car is smoking. cylinder 1 seem to have oil on the piston. all exhaust valves in all cylinder are white. what causes this white corrosion to the exhaust valves
Old May 24, 2009 | 07:40 AM
boostedeg302's Avatar
bump for info
Old May 24, 2009 | 12:54 PM
rev-speed's Avatar
just pull the head it takes u less than an hour..........................................
a manchine shop can tell it all...
Dc4one8
Jun 16, 2014 06:27 PM
HaNgTiZZy
Aug 7, 2009 08:40 AM
92ehatch
21
Nov 13, 2007 01:58 AM
tuan...
Sep 7, 2004 04:27 PM
