Help... car wont stay on when its cold... (Boosted EM1)
Old May 22, 2009 | 11:59 AM
cm8719500's Avatar
Default Help... car wont stay on when its cold... (Boosted EM1)
Hey guys I need some help..
I have a turbo b16A and it wont stay on when its cold...
I have to hold the gas down to be abel to start it.... and I have to keep gas on it or it will turn off...
even when its warm and I come to a dead stop.. it turns off every onece in a while...
anyone have the same proble or any useful info.. I have an MSD coil but I dont know if that helps at all
Thanks...
Old May 22, 2009 | 06:49 PM
EKhatch914's Avatar
Default Re: Help... car wont stay on when its cold... (Boosted EM1)
Could it be the map sensor reading the boost causing this? I have the same problem with my JR Super charged B16a2 with a chipped p28 un-tuned till i fix all the problems!
I tried cleaning the IACV and disconnected it, ran it with two wires direct to the battery and it clicked so I know its at least responding. I checked for vacuum leaks all over, checked all my lines, checked my PCV and it has play when i shake it so I assume its still good because its not locked up. I checked my grounds, I'm getting fuel at idle and when the throttle is open.
My boost/vacuum gauge is reading 15psi vacuum at idle which I'm pretty sure is normal and I'm boosting to 6psi like I should be.
I tried using "The Missing Link" http://www.inlinefour.com/missinglink.html and it caused my car to shut off while i was driving and wouldn't let me start the car. I had to remove it so that I can get the car started.
I swapped out my computer with my bro-in-laws computer but his caused my car to run too rich. Its chipped also. The car still shuts off anyway...
I am stumped... No Cels to diagnose... Next step is to replace the IACV and run a check valve at the map sensor to see if that helps... Check the valve clearance and timing also.
If non of this works.. I'm going to have to bite the bullet and take it to the dealer or find someone that works on honda in town and worry about it going missing the next day...
SCV_GSR
Engine Management and Tuning
Jan 26, 2010 12:46 PM
omg_jdm
Feb 26, 2009 07:23 PM
slowhonduh93
Jan 11, 2006 10:13 PM
twkdCD595
May 25, 2005 08:04 PM
AspectIndustries
May 23, 2005 04:22 AM
