need help figuring out if my RC injectors are saturated or peak&hold??
Old May 22, 2009 | 11:32 AM
cristegra09's Avatar
Default need help figuring out if my RC injectors are saturated or peak&hold??
im not sure if im in the rt forum since im kinda new at this.. but i need to know if the rc injectors i have in my car are saturated or peak&hold..
i did not purchase these so i dnt know..
all i can read off the injector is " rc sl9-440"
so if u know ur injectors plz let me know wat type i have.. i need to know because the car was running like **** and mite need a resistor box for them..
thanx n advance..
Old May 22, 2009 | 12:55 PM
bluedlude's Avatar
Default Re: need help figuring out if my RC injectors are saturated or peak&hold??
they are saturated, no resistor box needed
Old May 22, 2009 | 12:56 PM
SOHC_MShue's Avatar
if you ever need to know in the future check the resistance across the injector with an ohmeter. Around 0-4ohms will be peak and hold and higher around 12ohms are saturated.
Old May 22, 2009 | 01:06 PM
ok thanx.. well im fukin stuck rt now!!! i thought i needed a resistor box cause my car was runnin like ****..
i start the car wit no issues n when rev it it wouldnt let me rev higher then 45k rpm and when i took it for a drive it would not let me get past 1st gear speeds even when shifted to 2nd n 3rd gear..and when would floor it it would jus boggle horribly..
i thought i would be since i needed a resistor box but i guess since that not my problem idk wat else it could be..
im up for any suggestions..
Old May 22, 2009 | 02:42 PM
93turbo16's Avatar
Do you have a chipped ecu that is setup for those injectors?
If not that is your problem.
Old May 22, 2009 | 02:49 PM
no i didnt know u needed a chip for the saturated 440 Rc injectors.. i bought the ecu stock from a junkyard and the injectors were already wired on the harness when i bought it.. so lets say that my issue where can i get the chip for the ecu to run those injectors right??
Old May 22, 2009 | 03:10 PM
93turbo16's Avatar
I can help you out in that department. See my sig.
Old May 22, 2009 | 03:16 PM
yea i read ur sig but i didnt wanna look like a fool and ask u if u had any...lol
well i was jus thinkin that my prob was somewhere n the lines of tunning it correctly..but like i said im up for anything.. how much would it cost to get a chip to run those saturated rc injectors and is it hard to install n ecu myself?
Steeve_Civic
Dec 4, 2011 10:11 AM
civicsaremean
Jun 29, 2007 06:17 AM
jackiechan
Apr 19, 2007 11:20 AM
thid92
Aug 10, 2003 08:23 PM
