B18C1 EG ECU question
Old May 22, 2009 | 08:23 AM
EG.red's Avatar
Default B18C1 EG ECU question
Well I'm running on a P73, I looked around and people are using P28's and P72's which one's best?
Old May 22, 2009 | 08:35 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: B18C1 EG ECU question
doesnt matter
Old May 22, 2009 | 08:36 AM
I'm not Rick!
if you plan on lots of power down the road trade it for a p28
Old May 22, 2009 | 08:51 AM
iwanttokillgod's Avatar
if your motor is stock then the p72 but then you need to hook up the butterflys, chipped p28 you can do what you want
Old May 22, 2009 | 09:13 AM
EG6Boy702's Avatar
There both good, there only the best when the ecu's have bin tuned and chipped
Old May 22, 2009 | 09:26 AM
redlinetuning's Avatar
you can chip an OBD1 P72 just as easily.
Old May 22, 2009 | 09:51 AM
weavertime1's Avatar
How are you running on a P73 in an EG? Are you using an OBD1 to OBD2 jumper harness? Also if the B18C1 has the oem intake manifold the P73 would not even open your intake butterflies at higher rpms because the B18C or B18C5 that the P73 runs never had that type of intake manifold. An OBD1 P72 would be the best bet for now.
Old May 22, 2009 | 09:53 AM
I'm not Rick!
if i was you id get the type r style intake mani and throw the stock gsr mani in the garbage
Old May 22, 2009 | 04:02 PM
EG.red's Avatar
Yea, I know, the car came with it and now i'm trying to replace it because I know it's not the right ECU. He was just using it to get around.
Old May 22, 2009 | 04:11 PM
omgwtfbbq's Avatar
P72, unless you plan on removing your IABS, or changing to an aftermarket IM, then get a P28.
Old May 22, 2009 | 04:13 PM
EG.red's Avatar
k thanks everyone, I think I'm gonna go with the P72 since I'm too broke to race. =[
Old May 22, 2009 | 04:27 PM
omgwtfbbq's Avatar
since you have a p73, you may want to check if they wired in the IABs. Should be at pin location A17 on the ecu.
Old May 22, 2009 | 06:48 PM
A real P73 wouldn't even work in your car though...confused?
Old May 22, 2009 | 07:34 PM
American.Graffiti's Avatar
^ True
^True.
Old May 22, 2009 | 07:48 PM
EG.red's Avatar
Hmmm, I'm confused too now.
Old May 23, 2009 | 12:34 AM
shytdoode's Avatar
i got a chipped p28 with a jumper harness for sale in intrested....
Old May 23, 2009 | 12:42 PM
EG.red's Avatar
Here's my ECU setup, hopefully it will eliminate confusion even though it hasn't for me.
And I checked the barcode on the ECU it said P73 on it.
Old May 23, 2009 | 04:21 PM
omgwtfbbq's Avatar
looks like you are converted from OBD1 to OBD2....
Get a chipped P72 OBD1 ecu....plug right in, everything will be nice
(check to make sure your IABS are wired. look on google, lots of tutorials).
You can get an OBD2 ecu, but you can't tune them.
Old May 25, 2009 | 07:01 PM
OK...now things are making a bit more sense. Your car is OBD1 and is jumped to OBD2, which allows you to run the OBD2 P73. If you have a B18C1 with the typical B18C1 inake manifold an OBD1 P72 ecu would be optimal. Just remove the jumper and add the OBD1 P72. Good luck!
Old Jun 18, 2010 | 11:07 AM
pjw#703's Avatar
25 Year Member
And now for the stupid questions: what's the black box with the green thingies on it ?? ........
Old Jun 18, 2010 | 11:58 AM
cyrusli's Avatar
p28 has more potential as everyone's already hinted at. I recently did a swap and went to the p28 because the EG I have is on OBD1, it was easier to chip and modify. P72 has more restrictions because of emission controls during that time.. hence the b18c has two o2 sensors. p28 pollutes the air more . Someone correct me if i'm wrong.
Old Jun 18, 2010 | 06:59 PM
CivicSpoon's Avatar
It's not a box. It's a plastic "encasing," that helps to keep the bundle of wires out of the way, when the ECU gets bolted down.
b18c_Ek101
Mar 12, 2010 12:56 PM
hYbRid_Eg6
Jul 31, 2005 09:36 PM
sieger
Sep 2, 2002 12:46 PM
StinkyTofu
Apr 15, 2002 01:12 AM
