Air Conditioning/Belt problem
Old May 22, 2009 | 08:06 AM
FSUseminoleEM1's Avatar
Default Air Conditioning/Belt problem
Having some AC trouble on a '99 Si.
Ok so last week, when I ran the AC, a belt would squeal when I gave the car gas. Now, when I run the AC, no belt squeals, and the air doesn't blow cold.
Any ideas as to what's going on?
Old May 22, 2009 | 08:42 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: Air Conditioning/Belt problem
...change the belt
Old May 22, 2009 | 09:03 AM
Str8EJ's Avatar
unclear on what occurred to affect the system's behavior.
did it just change overnight or were you messing with it?
[go noles!]
Old May 22, 2009 | 09:07 AM
Group Tenacity's Avatar
Did you look to see if the belt is still there?
Old May 22, 2009 | 09:10 AM
belt is still there. and no i haven't made ANY adjustments at all.
Old May 22, 2009 | 09:11 AM
also- is it the belt that's on the alternator that is also attached to the compressor? b/c it's definitely tight enough. BUT there is one that's lower that has a good bit of slack in it.
Old May 22, 2009 | 09:21 AM
Former User's Avatar
Old May 22, 2009 | 09:27 AM
I'm not Rick!
you only need the altenator belt. rip everything else out....jus kidn
zackn8
Aug 30, 2010 01:23 PM
19crx93
22
Aug 16, 2010 03:46 PM
b18c196
Aug 3, 2006 12:59 PM
oxSLEEPERxo
Mar 20, 2005 11:23 AM
Integrity 19
Mar 9, 2005 10:13 AM
