Need help with 96-00 civic fog lights....
Old May 21, 2009 | 11:22 PM
raidacaipo's Avatar
Default Need help with 96-00 civic fog lights....
Where do these 2 go to?
I know 1 of them is suppose to go into fuse #5 but what about the other wire? there are 3 plugs total. 2 female single pin plugs and 1 male single pin plug
I already connected the 1 male single pin lug to another plug that was taped up with blue tape as instructed
These switch light harness are similar to the oem ones. Its not a depo brand and it doesnt connect straight to battery. Im lost on these instructions.
http://www.passwordjdm.com/Install_N...tall_Notes.pdf
I just need to figure out the 2 plugs mentioned on top.
Old May 21, 2009 | 11:30 PM
raidacaipo's Avatar
Default Re: Need help with 96-00 civic fog lights....
help
Old May 21, 2009 | 11:47 PM
raidacaipo's Avatar
i guess everyones asleep..
Old May 21, 2009 | 11:56 PM
raidacaipo's Avatar
bump
Old May 22, 2009 | 11:38 AM
raidacaipo's Avatar
bump
Old May 22, 2009 | 11:39 AM
raidacaipo's Avatar
also need to know what is stock fuel pressure level for a h22a? is it the standard 40psi?
Old May 22, 2009 | 12:40 PM
redlinetuning's Avatar
See #25 in the PDF link you posted. Connect the switch harness wire (red) and the fog light wire (red) together.
Old May 22, 2009 | 12:49 PM
raidacaipo's Avatar
see the problem with that diagram is that I dont have those red wires.. it doesnt come with it unless its depo or something.. the red wire you see in the background on picture 1 (not the red one im holding) is for my old fog light setup which were depo..I just forgot to unplug it.. anyways I bought new fog lights and the switch and fog harness are very similar to oem. As you know depo fog lights connect directly to the battery whereas oem or these fog lights dont..
Old May 22, 2009 | 03:53 PM
Kista20's Avatar
I wired fog lights on my 97 hx and all I bought was the oem switch, bumper harness and the one for under the dash that connects to the light switch and I belive the other end went to a brown wire or connector. I never had to plug anything into the fuse box and everything I got came straight from the dealer. The one under the dash came with an inline fuse holder but I also needed to get a relay which is the same one that the horn uses oh and the relay on mine didn't go in the fuse box it connected to the harness itself.
Old Jun 2, 2009 | 01:16 PM
raidacaipo's Avatar
long time bump.. still need help!
Old Jun 2, 2009 | 01:58 PM
dyprokski's Avatar
New User
ok i gotch you i wired my own fog lights got an aim if not let me know if so go to battleholexkrue
Old Jun 2, 2009 | 02:15 PM
dyprokski's Avatar
New User
red one goes into #5 and one of the white wires goes to any *** plug, i tapped my radio
Old Jun 2, 2009 | 02:17 PM
dyprokski's Avatar
New User
if you still need help ill pull my under dash cover off just for you
Old Jun 2, 2009 | 10:30 PM
raidacaipo's Avatar
yes I do... please help me and I dont have aim
Old Jun 2, 2009 | 11:09 PM
dyprokski's Avatar
New User
you in cali... where about`s. just askin maybe i can help with the set up. ok well i will update this message in da morning, or you can call me personally in regards to your situation. my personal email is battleholexkrue@live.com, i will stay online for another hour if any ???`s tonite... O.C. time 714 area
Old Jun 2, 2009 | 11:52 PM
dyprokski's Avatar
New User
ok i found sumthing that may be detailed and usefull with sum pic`s. https://honda-tech.com/forums/lighting-107/fog-light-loom-install-96-98-civic-2409640/
i hope it helps
Old Jun 3, 2009 | 12:10 AM
dyprokski's Avatar
New User
http://www.hondacivicforum.com/forum...ad.php?t=61880
heres another
Old Jun 3, 2009 | 02:03 AM
raidacaipo's Avatar
sorry those 2 doesnt help.. I will take it apart and take a picture of exactly what wiring I have.. its really weird compared to my old depo ones.. the old depo ones connect straight to the battery whereas these dont..
JDM BEEF
Apr 7, 2010 08:49 AM
DOMAN!EJ8
16
Sep 2, 2009 10:17 PM
alacard
22
Jan 8, 2008 06:28 PM
crazi92hb
Jan 16, 2006 05:04 PM
kerryk
Apr 26, 2003 03:54 AM
