CR-V cd player/radio into DC integra?
Quick question, will a 1998 Honda CR-V cd player work in a 96 Integra?
I know that it will NOT be plug and play but will it be possible for me to wire it any way?
Thanks
Thanks
The plugs are the same, and I recall the mounting being similar. You may need to play with the fit/mounting if anything, but it should work. The harness will be plug-N-play
Kirk R
Kirk R
It may or may not be plug and play, 98 was the year the "change over" year, some Honda/Acura switched to the newer plug and others did not, some Integra still used the older plug all the way up to 01.
Not a biggie, aftermarket plugs, [if needed] can be had at any car audio shop or online.
Mounting will be a bit of a bigger problem, the 98 CR-V used an ISO mounting system, [screws through brackets into the sides of the HU, the 96 Integra uses the rear mount system, [screws through a bracket into a "lip" at the back of the HU, also not a biggie, but you will have to make the "adapter", it is not avalable from anywhere as far as I know. 94
akhom
Audio / Security / Video
Feb 5, 2003 06:06 AM
blacksoul
Jul 17, 2002 09:31 AM
