help ! my car wont go past 3k rpm
Old May 21, 2009 | 07:48 PM
Eg_mE's Avatar
Default help ! my car wont go past 3k rpm
i have a ls/vtec swap in a EJ recently my differentials went out on my b16 tran's so we just swapped to a gsr trans and now it wont go past 3 k i feel as if im losing so much power and we checked to make sure everything was plugged and it was. At this point we're clueless my car was is j-k tuned, my friend suggested that it could be my ecu, he said it could be acting up since it was tuned.... and that doesnt make sense to me so please h-t pimp my ride and help me get past 3k
Old May 21, 2009 | 08:04 PM
1992hondacivicvx's Avatar
Default Re: help ! my car wont go past 3k rpm
well i think i mite be harness or ur knock sensor my car did the same thing and i got a vtec harness with a knock sensor it made my car go past 3k hope that helps
Old May 21, 2009 | 08:15 PM
xXvtec5kXx's Avatar
try a different ecu?
Old May 21, 2009 | 09:15 PM
Ya Digg's Avatar
Do you have a check engine light? if so find it and fix it sounds like your in limp mode which wont go past 3k.
Old May 21, 2009 | 11:14 PM
Eg_mE's Avatar
there's no check engine light at all. Everything seems to be plugged in correctly, the car just wont go past 3-k i feel a huge power loss, i can barely get up to 25mph with flooring it
Old May 21, 2009 | 11:27 PM
waaBAAH's Avatar
does the check engine light come on for 3 seconds with key on engine off?
Old May 22, 2009 | 12:05 AM
Eg_mE's Avatar
no check engine light after then engine is off either....thanks for the suggestion tho
Old May 22, 2009 | 12:09 AM
jdm inc's Avatar
try a different ecu.
Old May 22, 2009 | 07:17 PM
bubbaparks2121's Avatar
ground wires?
Old May 23, 2009 | 03:34 PM
Ya Digg's Avatar
dcletten
Nov 7, 2008 09:50 AM
civicex_88005
Jun 21, 2005 02:17 PM
RedRex8
Aug 19, 2003 08:48 AM
hatchboy93
14
Apr 23, 2003 10:02 PM
