Clutch Problem
Old May 21, 2009 | 02:41 PM
Hill4589's Avatar
Default Clutch Problem
I have a 92 cx hatch with a z6 swap. I went to get in my car today after parking it this morning and i went to press my clutch pedal and it was already on the floor. I brought it back up with my hand and tried pressing it again and it sunk and stayed to the floor. I replaced the slave cylinder and bled the clutch but still the same problem. clutch fluid is ok. What else can it be?
Old May 21, 2009 | 02:52 PM
civic_driver's Avatar
Default Re: Clutch Problem
The clutch master cylinder is most likely out.
Old May 21, 2009 | 02:57 PM
Hill4589's Avatar
Is that what gives it the spring back action?
Old May 21, 2009 | 04:20 PM
Either that, or the clutch fork is broken, or there's air in the system. Most likely the master cylinder though. You can check if it's leaking on the interior by the clutch pedal.
Old May 21, 2009 | 05:11 PM
jhonda239's Avatar
haha happens to every1. they replace the cheap stuff and then they finally have to pay alot for the clutch master cylender. its and easy job too. just a bit expensive.
Old May 21, 2009 | 05:14 PM
shailoche's Avatar
Could be the helper spring...too...maybe...
Old May 21, 2009 | 05:15 PM
b16racereg6's Avatar
do the master happend to me befor.. u goa bleed it mad times tho until u get it back u just keep bleeding it and bleeding it.. ok. g/l
Old May 21, 2009 | 05:41 PM
Pothole987's Avatar
Fail english? Wow that was hard to read.
Your seal for your clutch master cylinder is wore out most likely. looks up under the dash to where the clutch goes through the firewall and look to see if the piston is greasy. it problaly lost all its pressure so 'spring' back up.
96civic turbo
Transmission & Drivetrain
Jun 5, 2010 11:09 AM
hannslebo
Mar 24, 2009 01:53 PM
Greenery18
Jul 8, 2005 04:22 PM
FLCivic
Jun 30, 2004 03:48 PM
vpforeva
Dec 24, 2001 01:20 PM
