Clutch Problem
Clutch Problem
I have a 92 cx hatch with a z6 swap. I went to get in my car today after parking it this morning and i went to press my clutch pedal and it was already on the floor. I brought it back up with my hand and tried pressing it again and it sunk and stayed to the floor. I replaced the slave cylinder and bled the clutch but still the same problem. clutch fluid is ok. What else can it be?
Re: Clutch Problem
Either that, or the clutch fork is broken, or there's air in the system. Most likely the master cylinder though. You can check if it's leaking on the interior by the clutch pedal.
Re: Clutch Problem
haha happens to every1. they replace the cheap stuff and then they finally have to pay alot for the clutch master cylender. its and easy job too. just a bit expensive.
Re: Clutch Problem
Fail english? Wow that was hard to read.
Your seal for your clutch master cylinder is wore out most likely. looks up under the dash to where the clutch goes through the firewall and look to see if the piston is greasy. it problaly lost all its pressure so 'spring' back up.
FLCivic
06-30-2004 03:48 PM
