help please motor bogging
Old May 21, 2009 | 11:03 AM
Yeah Daybid's Avatar
Default help please motor bogging
i have a 96 accord automatic sedan and when im stopped at a light my motor boggs while in D also whle driving it boggs, if i try sometimes to go from stopped to accelerate it will cut out and die. running very rich
checked the ignition
new dizzy
the ecu doesnt seem to have any burn spots
please help cant think of anything else other than maybe a new ecu
please please please help
Old May 21, 2009 | 11:45 AM
Default Re: help please motor bogging
bump
Old May 21, 2009 | 03:01 PM
accord99power's Avatar
how do u know its running rich? check sensors out and clean the map sensor first. check intake is not completely clogged.
Old May 21, 2009 | 03:53 PM
94h22acord's Avatar
ur o2 sensors are probably shot. when their bad the car will go into safe mode and dump a ton of fuel. i would also check spark plugs, wires, fuel filter.
Old May 21, 2009 | 10:15 PM
masterkill455's Avatar
yeah? my car is very gutless and i did plugs wires cap rotor cleaned iac cleaned fitv cleaned tb and adjusted valves and it ran good for a while now its boggy again
Old May 22, 2009 | 05:27 AM
valves wont make a difference that that much at least, clean the sensors again and see if it gets better again (sensor problem if yes) also when the last time fuel filter has been replaced and fuel injector cleaner been added to your fuel?
Old May 22, 2009 | 07:05 AM
accord_raffi's Avatar
vacuum leak?
Old May 22, 2009 | 07:41 AM
NiChRiS's Avatar
bump
Old May 22, 2009 | 08:39 AM
Originally Posted by NiChRiS
bump
Why the bump? no other tests have been performed or reported by Yeah Day bid .
Old May 22, 2009 | 09:30 PM
sensors and all are clean I run injector cleaner every oil change and the filter is 10k old, car pops a little at idle too
Old May 23, 2009 | 08:10 AM
vacuum leak test, you can use intake system cleaner to spray on your vacumm lines and by the throttle body, if you hear a difference when you spray in theose areas you have a leak, or just hookup a cheapo vacuum tester thats the easiest.
Old May 23, 2009 | 07:06 PM
did that already, no leaks. Car only does this sometimes, local honda tuner says has to be a bad o2 sensor but i dont think so no CEL..
duck5985
27
Jun 30, 2015 10:02 AM
duck5985
Jun 20, 2015 06:31 PM
eghatchfla
Sep 7, 2010 06:03 PM
N hatch
14
Jul 11, 2004 06:21 PM
chulopilong
Feb 15, 2004 12:44 PM
