rear disc brake questions
I have a 99 civic coupe I swaped the rear trailing arms for disc, the guy I bought it from said it was from a JDM civic. The brakes are now starting to go, if they are JDM is there even a difference between integra or civic si discs and pads, also i noticed after i bought them that one of the trailing arms was for a car equiped with ABS, should this change the parts I wouls need? pads and discs look the same, Thanks in advance
No, the fact that they were ABS brakes does not change any parts, they will use the same pads as non-ABS equipped rear disc brakes. Not sure about the difference from JDM Civic brake pads but I believe they might be like GSR (Integra pads) but someone correct me if I am wrong.
luispizarro25
Jun 17, 2009 03:25 PM
