2000 civic hid conversion
Old May 21, 2009 | 09:18 AM
skaternak's Avatar
Default 2000 civic hid conversion
i put on the hid and my lights shine in the air i aimed it down but since the headlight is so big it shines a beam into the air still. Is there something I can get to put into the headlamp so it doesnt reflect off the bottom of the headlamp?
Old May 21, 2009 | 09:26 AM
ifIexplode's Avatar
Default Re: 2000 civic hid conversion
Yah, retrofit a projector into your headlight housing. Right now your blinding everyone.
Old May 21, 2009 | 09:29 AM
skaternak's Avatar
i dont think im blinding everyone cause my lights are aimed to the ground and the angle the light shoots in the air say the angle is 2 o'clock
Old May 21, 2009 | 09:30 AM
FearTheH's Avatar
do a retro fit... and get rid of the crappy ebay plug n play kit. go into the lighting section on HT and look up how to do an HID Retro fit...it gets expensive but is the RIGHT way to do HID's on a non hid car.
Old May 25, 2009 | 02:34 PM
98civdx's Avatar
Master Detailer
my lights used to do the same thing there really is no way to fix this, due to the civics crappy *** lights
Old Jun 1, 2009 | 07:39 AM
djjosehernandez's Avatar
just put it in a angle were it does not toch the bottom of the housing and dont get to close to the car in the front
Old Jun 1, 2009 | 07:53 AM
kp's Avatar
kp
Instead of putting a reflector on top of the hid assembly, try taking it back apart and painting a square of matte black below the bulb so it doesn't reflect as much. Make sure it's heat paint, I'm sure those hid's get pretty toasty.
Old Jun 1, 2009 | 08:17 AM
98civdx's Avatar
Master Detailer
ill try this tonite.
when im behind my friend in his dc i blind the hell out of him when he looks in the mirror
being as hes dumped and im not that low.
Old Jun 2, 2009 | 09:54 PM
98civdx's Avatar
Master Detailer
i just did, and wow.
no more light way up in the air on the drivers side, the passagner side im going to try moving the bulb in another spot, i moved it and it did make a lil difference but not much.
but now no more throwing light into on coming traffic, now i kinda like my hids lol
Old Jun 2, 2009 | 10:14 PM
Tractor_Boy's Avatar
whats a good "kit" to retro it to HID correctly????
Old Jun 2, 2009 | 11:40 PM
fastrxu's Avatar
what exactly did you do to the headlight housing?
You spray painted the INSIDE of the housing with flat black high temp right?
I'll try that too.
Old Jun 2, 2009 | 11:57 PM
I'll try that too.
not the best of ideas from past experience............
Old Jun 4, 2009 | 02:39 AM
fastrxu's Avatar
why would you say that? can you explain?
Old Jun 4, 2009 | 06:11 AM
cuz its very easy to paint too much and mess it up if you dont know what your doing, and it doesnt look very good either, but what I did this on were mustangs, few GM cars and some trucks also the paint generally doesnt last very long either
*R4993r0*
Aug 19, 2012 08:17 AM
AhhNickk
Nov 30, 2009 12:12 AM
DC5BOI90
Oct 10, 2008 06:53 PM
cebbeler
Lighting
Apr 13, 2008 09:30 PM
Isaac
Jul 23, 2001 09:48 AM
