what degreaser to use for engine bay
Old May 21, 2009 | 05:13 AM
civic-one's Avatar
Default what degreaser to use for engine bay
One quick question. What engine degreaser do you guys use on your engine bay. My engine bay is kind of hurting my eyes to see because here on the island we get alot of rains and then mud and all gets in the bay not including dust that dries up in there. What do you guys use im planning to use simple green . . . .good or bad? Let me know on some comments I dont want to ruin my bay.
Old May 21, 2009 | 07:47 AM
KevinBrown's Avatar
Default Re: what degreaser to use for engine bay
Simple green and pressure washer. Wrap up your distributor and any other electrical stuff you don't want wet. MAINLY the distributor. Everything else will be ok as long as you aren't trying to cut through wires on purpose.
Old May 21, 2009 | 09:05 AM
str8venom99's Avatar
simple green spary nine purple power will work
Old May 21, 2009 | 09:18 AM
Eyger's Avatar
if you head to your local auto supply store like pep boys or kragen or something like that, you can get a can of cleaner called 'foamy engine brite' I've used it a bunch of times before. It cuts through all kind of grease oil and dirt. The first time I bought it, was when one of the engine motor mounts broke and splattered grease stuff all over the side of the valve cover, I couldn't get it off with anything, eventually i tried the foamy engine brite, and it came out in 10 seconds. good stuff.
Old May 22, 2009 | 05:11 AM
civic-one's Avatar
Thanks guys for the help I will be trying it out and maybe post a little sneak peak picture thanks again.
Old May 22, 2009 | 05:59 AM
dntnedvtec's Avatar
spit and elbow grease
Old May 22, 2009 | 10:18 AM
redboost10's Avatar
simple green and then some cd-2
Old May 23, 2009 | 03:13 AM
civic-one's Avatar
Please keep your negative comment to yourself.
Old May 24, 2009 | 12:05 PM
Race Egr's Avatar
Just becareful with simplegreen it oxidizes aluminum
Old May 24, 2009 | 04:24 PM
bakertime's Avatar
I would definitely try the foamy engine brite...I've used both that and Simple Green, and the foam really seems to cut better. Simple Green is great stuff, but it's not really designed to cut through thick stuff like that.
Old May 24, 2009 | 04:27 PM
redboost10's Avatar
if you want some really strong stuff, get some amazing roll off. i usually cut that stuff 20:1 and it still kicks up some baked on stuff.
i need to get some of that engine brite stuff
Old May 24, 2009 | 06:23 PM
civic-one's Avatar
But theres a problem here. We dont have them Pepboys or Autozone its really hard for us to find wat you guys are using there because haaha its a small island. We only have Napa and ebay to look for stuff that we really want so maybe ill give that a shot at ebay. thanks for the replies all i will be starting to clean it up soon then ill post up pics thanks again. Keep the replies comin thanks for all the input.
Old May 24, 2009 | 06:37 PM
taggart_lumpy's Avatar
i use the purple power stuff
Old May 24, 2009 | 06:46 PM
bakertime's Avatar
Napa should have Engine Brite
Old Jun 28, 2009 | 11:15 PM
jdm junky's Avatar
dosent that stuff turn your motor a weird color...almost like it makes the alluminum look real dry?
Old Jul 1, 2009 | 03:52 PM
mike9571's Avatar
Brake clean best hands down
toolfan020
Paint and Body
Jul 30, 2008 06:58 PM
RedneckRicer
Paint and Body
May 10, 2008 06:33 AM
gursh d
Paint and Body
39
Nov 24, 2007 09:14 AM
sTill JDM
May 20, 2007 07:41 PM
beaterman
May 6, 2003 09:19 AM
