need help
Old May 20, 2009 | 10:19 PM
99ekcoupe's Avatar
Icon3 need help
got a 99 ex an my brake light suddenly stopped workin idk y i just got wheel bearing but i doubt that has anything to do, i checked all da fuses i replaced da brake switch an even the connector behind the drivers seat can any 1 help thanks
Old May 21, 2009 | 08:22 AM
eros18's Avatar
Default Re: need help
did you check the bulb yet?
Old May 21, 2009 | 08:45 AM
EL Vap133's Avatar
Bulb, fuses, wire disconnected? You mean the brake light in the tail light and not on the cluster/odometer right?
Old May 21, 2009 | 08:06 PM
99ekcoupe's Avatar
yes i checked them i even replaced them
Old May 21, 2009 | 08:10 PM
99ekcoupe's Avatar
yes my taillight when i press the brakes they dont light up. i checked fuses bulb i replaced brake switch an the connecter
Old May 21, 2009 | 09:36 PM
shawn_crx's Avatar
2 post with the same thing???
anyways try this one
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/brake-lights-not-working-2000-ex-coupe-help-2573438/
Old May 22, 2009 | 08:25 AM
99ekcoupe's Avatar
https://honda-tech.com/forums/showthread.php?t=2573438
myb kinda new so didnt kno were 2 post sry but thanks 4 da info gonna try it out
Old May 22, 2009 | 08:31 AM
EL Vap133's Avatar
Have you done any wiring recently?
Old May 22, 2009 | 09:20 AM
EG6Boy702's Avatar
Wiring is the only thing it could be then
Old May 22, 2009 | 09:29 AM
Former User's Avatar
Double check fuse 52 under the hood. If fine, next check whether you measure battery voltage at the WHT/GRN wire in the brake switch connector. If also fine, check whether the G601 ground wire is broken, loose, disconnected, or corroded.
lickety
Honda Civic (2001 - 2005)
Aug 25, 2013 12:50 PM
DC2-TEG
Dec 10, 2010 03:53 PM
jxhxb
27
Nov 25, 2007 10:25 AM
vinny76010
Apr 20, 2006 12:32 PM
HyBriDcxR
Aug 9, 2003 11:46 AM
