99 Civic Cluster Wire Plugs
Old May 20, 2009 | 03:59 PM
L0wNsL0w's Avatar
Default 99 Civic Cluster Wire Plugs
i just took out the instrument cluster on my 99civ to try n fix the clear cover that was cracked n when i pulled out the cluster the yellow plug wasnt plugged in. does that matter? is it supposed to be unplugged?
also if anyone knows where i can get the clear cover that would help cuz i dont think there's a way to fix mine n i dont wanna buy a whole other cluster.
thanks all
Old May 20, 2009 | 04:11 PM
geneeunit's Avatar
Default Re: 99 Civic Cluster Wire Plugs
yellow plug is for SRS.
plug it in, the cover can be purchased at the dealer i think..
Old May 20, 2009 | 04:13 PM
L0wNsL0w's Avatar
awesome thanks-
the SRS light came on last week n i took it to my mechanic to see why it was on so i guess he just unplugged it- thats not cool
Old May 20, 2009 | 09:21 PM
shawn_crx's Avatar
hope he didn't charge u a arm and a leg
Old May 20, 2009 | 09:41 PM
Former User's Avatar
That's definitely not right. I'd have a chat with him.
Plug the SRS connector in, jump the service connector, and then read the SRS trouble code:
Old May 21, 2009 | 08:36 AM
L0wNsL0w's Avatar
he didnt charge me anything cuz since he had just replaced the steering column he said maybe he did something to set it off, so i took it back n i guess he just unplugged the yellow plug. so now what needs to be done so the light goes off the right way? and not just disconnecting the plug...
Old May 21, 2009 | 08:54 AM
EL Vap133's Avatar
If you look at the post above yours you will see the kind HT member posted exactly what you need to do to see what the problem is.
Old May 21, 2009 | 09:25 AM
L0wNsL0w's Avatar
what's an SCS connector?
Old May 21, 2009 | 10:08 AM
EL Vap133's Avatar
There is a picture of it in that illustration. It looks like the connection where you check your engine codes.
Old May 21, 2009 | 10:18 AM
civic_driver's Avatar
Here's how to find the service connector: https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
Old May 22, 2009 | 09:24 PM
L0wNsL0w's Avatar
what's the small gray plug behind the fuse box under the steering column for? its just hanging there.
Roryz
15
Apr 23, 2014 08:51 PM
Mrevann
27
Mar 6, 2011 09:46 PM
Townson
Sep 13, 2009 05:01 PM
sol2hatch
Feb 9, 2006 08:43 PM
CRXified
18
Dec 22, 2005 08:32 PM
