99 Civic Cluster Wire Plugs
i just took out the instrument cluster on my 99civ to try n fix the clear cover that was cracked n when i pulled out the cluster the yellow plug wasnt plugged in. does that matter? is it supposed to be unplugged?
also if anyone knows where i can get the clear cover that would help cuz i dont think there's a way to fix mine n i dont wanna buy a whole other cluster.
thanks all
thanks all
Re: 99 Civic Cluster Wire Plugs
Plug the SRS connector in, jump the service connector, and then read the SRS trouble code:
he didnt charge me anything cuz since he had just replaced the steering column he said maybe he did something to set it off, so i took it back n i guess he just unplugged the yellow plug. so now what needs to be done so the light goes off the right way? and not just disconnecting the plug...
Here's how to find the service connector: https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
Roryz
15
04-23-2014 08:51 PM
sol2hatch
02-09-2006 08:43 PM
