twin walbro fuel pump max whp output?
Old May 20, 2009 | 02:15 PM
turbo-crx's Avatar
Default twin walbro fuel pump max whp output?
when these are run parellel, how much power are these pumps good for with 1000cc injectors?
Old May 20, 2009 | 02:32 PM
miller's Avatar
Default Re: twin walbro fuel pump max whp output?
At that point the injectors will be your restriction. From what I have done you can get right to 700 on a turbo honda.
Old May 20, 2009 | 04:21 PM
turbo-crx's Avatar
thats what i thought. what if i have 1600cc injectors?
Old May 20, 2009 | 04:25 PM
miller's Avatar
I have tuned a few cars with the the full blown kit a 45lbs base and 1600s and have made 800+ with room to spare.
Old May 20, 2009 | 04:27 PM
jdmdc529's Avatar
My buddy r@mon made 750whp on e85 with 1600's and walbros in parallel. I am sure they would have no problem @ 850+ on gas
Old May 20, 2009 | 06:23 PM
kte324's Avatar
What about an intank walbro 255 feeding a inline walbro 255 on rc1000cc?
Old May 20, 2009 | 10:18 PM
96 GSR-T's Avatar
Made 550+hp on Ethanol with the fuel pressure not dropping off, I would think the 255 series combo would be good for close to 700hp on Gas if not more. Make sure you press in the pressure relief nipple on the top of the intank to get a little more out of it.
Old May 21, 2009 | 09:23 AM
turbo-crx's Avatar
yes i will be doing the pressure relief bypass when i install the second pump.
Old May 21, 2009 | 10:24 AM
96 GSR-T's Avatar
The inline does not have the relief valve, just the intanks.
Old May 21, 2009 | 11:30 AM
turbo-crx's Avatar
yea i have 2 intanks i will be doing the modifications to.
Old May 21, 2009 | 11:47 AM
kte324's Avatar
Well I just order an inline 255 and I hope it does the job of 650. I wonder what size lines I should use?
turbolsvtecej1
Sep 7, 2014 04:06 PM
boosted.si04
Dec 7, 2011 11:32 AM
sp00led
Honda S2000
Aug 11, 2011 01:04 PM
turboman2.2
Nov 30, 2010 02:56 PM
iownanrsx
Jul 2, 2007 12:38 PM
