Tein Springs from EM1 to DX Hatch possible?
Old May 20, 2009 | 12:14 PM
skylinerb26dett's Avatar
Icon2 Tein Springs from EM1 to DX Hatch possible?
hey everyone i was wondering if Tein s tech springs for a 96 and up civic coupe or em1, will fit on my 96 civic hatch dx?
i appreciate any help!
thanks,
-Shawn
Old May 20, 2009 | 12:48 PM
DC2-ProdUcTiOnS's Avatar
From: Howcome we park on driveways, and drive on parkways?
Default Re: will.....?
change your heading and someone may help you....i believe they will, but your much more likely to get a solid answer if your title was some thing like " Tein Springs from EM1 to DX Hatch possible?" then those who knows about springs and suspension will be available to help you....
Old May 20, 2009 | 12:54 PM
redlinetuning's Avatar
See rules and guidelines for threads.
As for your question, the springs will fit. It's a matter of spring rates for the different cars. The spring rates for a 99 SI will be different than one for an EX/DX/HX - CX/DX hatch.
Old May 20, 2009 | 01:48 PM
waaBAAH's Avatar
and for your information..tein is pronounced TAIN.. which ryhmes with GAIN, Pain, candy cane and the like.
Old May 20, 2009 | 01:51 PM
leroyb's Avatar
fvcking hate titles like this
Old May 20, 2009 | 02:54 PM
yoontim23's Avatar
Default Re: Tein Springs from EM1 to DX Hatch possible?
yes, it will fit/work.
Old May 20, 2009 | 02:59 PM
98civdx's Avatar
Master Detailer
what the hell does this have to do with what he is asking??
yes they will fit, as said already the rates are different. so its not going to lower the car as much due to the weight difference.
Old May 20, 2009 | 03:09 PM
98civdx's Avatar
Master Detailer
what the hell does lowering the car and weight difference have to do with anything? OP never asked that either.
i answerd his question what did you do????
he asked if they would fit,
and i was also letting him know that its going to lower the car as much. due to the different spring rates and weight.
what is has to do with is if you have spring for a certian weight (em1) and put them on the hatch that weighs less even a few hunderd pounds makes a huge difference in how the springs will work.
Old May 20, 2009 | 03:14 PM
waaBAAH's Avatar
i guess you can pee farther then i can
Old May 20, 2009 | 05:19 PM
waaBAAH's Avatar
i guess you cant pee as far as i thought.
1997 Civic DX/CX hatchback w/five-speed manual transmission
Civic DX/CX hatchback 1,590cc in-line four-cylinder SOHC
Peak horsepower @ 6,200 rpm: 106
Peak torque @ 4,600 rpm: 98
Overall length: 164.5 in.
Wheelbase: 103.2 in.
Width: 67.1 in.
Height: 54.1 in.
Curb weight (DX/CX): 2,253/2,238 lbs.
Suspension: F/R Four-wheel double wishbone
Brakes: F/R Disc/drum power-assisted
bottom line...96 hatch dx weighs 2,253
vvv heres 97 coupe vvvv
Curb Weight MT 2271
Curb Weight AT 2337
Ground Clearance 5.9
Height 54.1
Length 175.1
Top Type (Standard) Hard Fixed
Top Type (Optional) N/A
Track (Front) 58.1
Track (Rear) 58.1
Weight Distribution AT (Front) 62
Weight Distribution AT (Rear) 38
Weight Distribution MT (Front) 60
Weight Distribution MT (Rear) 40
Wheelbase 103.2
Width 67.1
Doors (Standard) 2
Doors (Maximum) 2
so i guess it really depends if the coupe is manual or automatic..give or take 50 pounds..lets just say manual transmission... M/T 97 coupe weighs 20 pounds more then OP 96 hatch DX.
so your saying that 20 pounds is worth even mentioning that his car will sit higher? install a system in the car..bring your fat girlfriend with...both cars would sit the same.
there!!!...so in closing..what did you bring to this forum?...nothing but random guessing and unsure facts about weights and ride height.
Old May 20, 2009 | 05:36 PM
98civdx's Avatar
Master Detailer
he said em1 which is a 99-00 civic si which weights in at 2612lbs and a 96 hatch weights 2,253 so thats 359 lbs.
not 20lbs
if it was for 96-00 it wouldnt matter hatch or not. but its an si.
Old May 20, 2009 | 05:46 PM
MonkeyMagic's Avatar
yes it'll work.
and its pronounced tey-in. stands for technical innovation
Old May 20, 2009 | 07:24 PM
wow everyone thanks for the replies!
yes my car is manual so what would you all estimate the drop to be?
i would like it anywhere from 1 inch to 1.5 inches?
Old May 20, 2009 | 09:28 PM
98civdx's Avatar
Master Detailer
if they are from a actual si not just a 96-00 i would say about a inch. maybe a lil more.
they are from a si right?
Old May 20, 2009 | 09:59 PM
waaBAAH's Avatar
thanks,
-Shawn
this is what OP said ...96 and up civic coupe OR em1.
see that or word in there...it means either or...one or the other...NOT just stritcly EM1....and OP was just asking for fitment..not ride height.
now the correct questions are taking place... "how high will my car sit now OP said..." "are the springs for a 96-00 coupe OR an EM1."
these questions would not have came up if it wasnt for me finding specs on weight of the mentioned cars from the OP. so i guess i still do pee farther then you.
you better hope for the sake of your argument that OP says 99-00si...your question sounds like doubt to me.
Old May 20, 2009 | 10:00 PM
waaBAAH's Avatar
Originally Posted by MonkeyMagic
yes it'll work.
its actually TAIN.. here is the tein commercial....its pronounced at the 25 second mark
http://www.youtube.com/watch?v=_n-1zkyvzuQ
here is the same version but diffrent language.
http://www.youtube.com/watch?v=_SxBp...eature=related
Old May 21, 2009 | 06:15 AM
so now im just looking for what the ride height would be for my hatch when i put them on?
Old May 21, 2009 | 07:34 AM
98civdx's Avatar
Master Detailer
well if you would answer my question we could helpp you.
if they are for a 96-00 civic they will lower the car 1.9 1.7 im guess thats what they lower to but not sure, it will be what tein said the springs will do
if its for a si bot that much because of the weight factor.
waaBAAH- look at the title to the thread title IT SAYS F****ING EM1!!!!!!!
and no its not prononced TAIN,
Old May 21, 2009 | 08:35 AM
waaBAAH's Avatar
you have anythign to support this? because i have two videos to support TAIN.
Old May 21, 2009 | 09:39 AM
hushypushy's Avatar
yes it'll work.
haha, it is 100% most definitely not tey-in. As mentioned earlier, it's tain/tane. It's one syllable and it rhymes with cane.
The other funny mispronunciation is Myoo-Jen. LOL
I have a BA in Japanese, so don't try to argue it
Old May 21, 2009 | 11:06 AM
i think its for a 96- up coupe or an em1?
Old May 21, 2009 | 12:15 PM
waaBAAH's Avatar
what everyone is trying to say and is saying is...
96-00 coupe is diffrent from an EM1 in terms of springs rates. but the springs will easilly match for your hatch
EM1 is 99-00 civic si
96-00 coupe is everything ...hx,dx,ex along with all the hatches,cx,hx.dx or whatever.
Old May 21, 2009 | 07:29 PM
thanks so much for your help!
just one more question, it will still lower it at least an inch right?
fireant
Nov 13, 2008 04:46 AM
Civiclized
May 10, 2006 06:15 PM
xfrankix2
May 10, 2005 05:01 PM
RoadconeTuning
Suspension & Brakes
Jan 15, 2005 02:41 PM
Blackrain
Feb 24, 2003 01:10 PM
