obdII to obdI what else? help!
Old May 20, 2009 | 09:10 AM
eggsi619's Avatar
Icon3 obdII to obdI what else? help!
im purchasing a 00 gsr blockwith a 99b16a2 head and a 95 gsr tranny. the guy that im buying it of from is including the obd1 harness. i know i need an obd1 dizzy as well. what else do i need to go from obdII to obdI? this is going in a 93eg by the way. thank for you help guys.
Old May 20, 2009 | 09:32 AM
sirt_eg's Avatar
Default Re: obdII to obdI what else? help!
this is cover plenty of times already, What car did it come out of? 96+ civic? integra? eg? more info so we can help you more. I love it when people just throw stuff at you without telling you whats what and expect you to know.
if its from a integra and its obd1, its a plug and play. just drop into your eg and your set.
if its from a 96+ civic your going to need a integra driver side engine bracket and upper mount, rear gsr/ls t-bracket, and if its the b16a2 shift linkage your going to need the gsr shift linkage cause its shorter than the b16, but I'm using the b16 on my eg and its fine. Just a little farther back thats it. Also your going to need to change out the obdII plug on the alternator to a obdI plug, just find a obdI alt and switch the plug and cover.
The dizzy you dont need to get a obd1 you can just switch the plug on the obdII dizzy to a obdI plug. Save you a lot of money or just trade it for a obd1. Other than that get yourself a p28 and chip it.
Old May 20, 2009 | 09:57 AM
eggsi619's Avatar
like i said its 2000 gsr bottom block with a 1999 b16a1 head.it was all put together but it was never swapped in a car if that really matters. im being as specific as i could. thanks for your help though.
Old May 20, 2009 | 10:07 AM
sirt_eg's Avatar
actually it does matter, cause if you dont know what car than you wont know what mounts you have. Since it was put together and its a gsr block I'm guessing it still has the gsr engine bracket on it. Just get the mounts and your good to go. 94+ integra upper mount, t-bracket, and tranny mount. And just do what I said on top.
One more thing, your going to need to rewire the intake sensor to a obdII, cause the b16a2 does not have the obdI sensor mounted on the intake manifold.
Old May 20, 2009 | 10:15 AM
hard_boiled_EG's Avatar
you will need obd1 dizzy, alternator, injectors (or what i do is just trim the injectors so the obd1 plugs will fit onto the obd2 injectors) you will also have to change the ?? i call it the mushroom forgot what it was called...thats all i can think of off the top...hope it helps
Old May 20, 2009 | 05:58 PM
eggsi619's Avatar
ohh.. okay okayy. cool thanks guys.
Jose robles
Jul 4, 2016 11:32 AM
JDM_CAM23
Nov 15, 2011 12:24 PM
Dymond
18
Feb 11, 2011 04:39 PM
jdm_integra_gsr
Sep 8, 2009 06:20 PM
Greenb16
14
Jul 24, 2006 09:27 AM
