help i have a cluster glitch
Old May 20, 2009 | 07:10 AM
TeamEK's Avatar
Default help i have a cluster glitch
I have ek civic and my cluster mphs goes up and down even if am not driving. I was wondering if i need to change my speed sensor, and where is that located at?
Also i have two clusters a si and my stock one and when i put each in my car the Fuel/Temp Gauge dosent work for both, do you guys know what might be the problem?
Old May 20, 2009 | 07:27 AM
shawn_crx's Avatar
Default Re: help i have a cluster glitch
check your wires on the speed sensor and it's locate at the tranny.
on the fuel/temp i would also check for the wires and the sensor.
Old May 20, 2009 | 08:25 AM
rick_rabies's Avatar
I'm not Rick!
if that doesnt fix it get a new cluster. these go bad
Old May 20, 2009 | 08:34 AM
killahatch's Avatar
i had the same problem about a month ago. pull out the plug that goes to the speed sensor and try cleaning it. mines was going crazy because it had water when i went through a flood. after i cleaned it the code went away and the speedometer started to work normal again.
doubleoazn03
May 29, 2012 03:02 PM
96honda_EK
Oct 19, 2009 05:50 PM
gorillapno
May 26, 2008 09:38 PM
bboyjimpy
16
Mar 16, 2008 06:28 PM
burgandybeast
Nov 2, 2007 02:30 PM
