wideband datalogging s200
Old May 20, 2009 | 07:09 AM
redline32's Avatar
Default wideband datalogging s200
Hey guys anyone have success dataloging a/f s thru the stock o2 plug with a wideband. tried to use the eld input like I do with the s300 but no luck. Hondata claims I can modify a old o2 plug to wire the 0-5 volt output from the wideband and it will work. Anyone have any luck with this?
thanx
Old May 20, 2009 | 08:33 AM
Spunkster's Avatar
Default Re: wideband datalogging s200
What version of software was the car tuned with?
Old May 20, 2009 | 09:41 AM
redline32's Avatar
I tune with re4
Old May 20, 2009 | 10:49 AM
Spunkster's Avatar
Options, Settings, Wideband Lambda tab.
Old May 20, 2009 | 11:00 AM
redline32's Avatar
Not to be funny or anything but that is wired thru the mdified o2 plug,, or is that thru the eld pin?
thanx
Old May 21, 2009 | 09:52 AM
Spunkster's Avatar
If you're saying youre trying to datalog through the ELD input using a modified O2 plug then of course it will not work, as the ELD has nothing to do with the O2 plug. You have to input the signal into the input on the ECU you select in the software.
Old May 28, 2009 | 07:54 PM
redline32's Avatar
No no, I was trying to use the output of the innovative to the eld on the s200 and was getting random figures compared to the dyno readout.. I was asking if anyone had used an o2 plug on the s200 with any success.. I tried with no luck, got the same weird numbers.
It read correct for about 2 mins. then went astray.
ExVtec
Honda S2000
Apr 18, 2009 09:34 PM
ShortbusEK
10
Jul 20, 2006 07:04 PM
96 GSR-T
Jun 19, 2006 05:09 PM
SpeedDreamz.com
Nov 9, 2003 08:01 AM
