D15b tranny on a D16z6?
I need a new tranny for my 93hatch. Its got the stock d16z6, and i found a guy selling a tranny from a d15b for a good price.
Will it directly bolt on without issues?
any major difference in gear ratios between the z6 tranny and the 15b tranny?
The ratios are actually quite a bit different...your car will feel much more sluggish I promise. it will bolt up and work just fine though. Good luck!
everything seems to point to them being almost identical, as I figured, since all the z6/y8/d15b engines are almost identical in performance as well. just check out this thread:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/y8-tranny-d15b-correct-2209049/
though with the amount of mis-information out there, I could still be wrong. All I know is that I'd much rather have a d15b tranny on my z6 than the b7 tranny I have on it now =P
https://honda-tech.com/forums/showthread.php?t=2209049
5G 92-95 USDM
tranny gear ratio M/T D15B8/D15Z1 D15B7 D16Z6
1st 3.250 3.250 3.250
2nd 1.761 1.761 1.900
3rd 1.066 1.172 1.250
4th 0.852 0.909 0.909
5th 0.702 0.702 0.702
REVERSE 3.153 3.153 3.153
FINAL DRIVE 3.250 3Dr:3.888 4.250
The D16Z6/Y8 are the best tranny's for D series. They are geared for best acceleration.
.Yes it's a direct bolt on, just make sure it's not a VTEC-E transmission, that would be a serious downgrade. I would hold out for a D15B tranny with LSD.
Do you guys mean the D15B VTEC trans (JDM)? In that case yes, some of those do have lsd, but they are not readily available in the U.S. The OP never said if it was a jdm tans or not...hmmm.
its a D15B, meaning its JDM automatically. Also LSD only came on the automatic D15B's as an option (dunno why). I'm pretty sure that the OBD2 Double Vtec version of the D15B also has a short tranny. That head goes from VTEC-E(3-valve) to normal(4-valve) to VTEC (higher profile cams), its not a gas mileage car like our HX. Its just an example of JDM Market getting speedy cars with insane gas mileage.
I've been in the game long enough to know that, but I've also been in the game long enough to know that people call D15b7s D15B2s D 15Bs, when all three are different animals entirely. When you post on here you need to be very exact...I am betting the OP is talking about A B7 or B2 trans, but I guess we will have to see if he reposts...
I've been in the game long enough to know that, but I've also been in the game long enough to know that people call D15b7's D15B's, when they are two different animals entirely. When you post on here you need to be very exact...I am betting the OP is talking about A b7 or B2 trans, but I guess we will have to see if he reposts...
o wow, B8 is a CX tranny. And a CX is actually 8 valve. I belive it has alot wider tranny. Dont put that on your car unless your boosting a ton and making alot of power lol. otherwise it will just be slow as ****.
cx and vx...very long
dx and lx (same engine) - long but not near as long as the cx/vx
ex and si (same engine) - shortest of the '92 - '95 d series transmissions (USDM)
Word!
Xxcivic97xX
11
Feb 17, 2017 05:40 PM
AlphaQup
14
Jul 4, 2003 09:28 AM
gulftools
Mar 30, 2003 09:50 AM
