PITA motor swap?
somthings gone wrong in my motor cause im burning a crap ton of oil...either my rings or valve seals are bad but its like a fog machine!
heres the motor
http://akroncanton.craigslist.org/pts/1136983090.html
has anyone seen a swap like this in a hatch?
heres the motor
so you got the SOHC accord F block? you gotta ask yourself at least one time before you installed the engine why it's only 150 bucks.
edit: do a leakdown and compression test and change your headgasket in my opinion and if you're good after that then you got off lucky.
i didnt but it yet
how do i do a leakdown?...headgasket was just changed b4 i got it, i have a head for it but its a 16 valve...will that work?...and i dont know what it came off of or if its vtec or not
sounds like a bundle of problems man. why not just look past this and try something less stressful. get some more information on the car as well. how do you do a leakdown and compression test? well unless you have the tools I would reccomend taking it to your local performance shop. I believe I paid 60-75 bucks for mine and then the shop can be able to tell you what kind of psi you have in each cycliner. then compare that to what kind of pistons are in the car and ask yourself; shouldn't there be more than 90psi in cylinder 3? at that point you can make a more educated decision wether the block has blown piston rings and if you want to deal with someone elses problems.
and the head you're talking about having 16 valves pretty much covers about every honda head so you're going to have to get more specific than that.
and he the guy that gave it to me said he bought i off ebay and it said D15B8...but my motor is a B8 and has 8 valves...the head was givin to me so i really cant say much more about it, would pics help at all?
I'm kind-of lost here, and I'm sure most others are as well.....
You say you have a D15B8 but then you posted a link to an Accord SOHC motor. Which one do you have?
Did you buy a swap recently? If you did...how do you know what was replaced on it?
Do you have any other issues other than smoking?
ok let me recap...my motor (D15B8)..is smoking really bad and im not sure why..i know its burning oil...the link was for a possible swap i could get but was wonder if it would be to much of a hassel, i have not bought this motor yet,.....but i have a 16 valve head that i have no clue what motor it came from..and was wonder how to tell if it was a vtec hed or not, and if it can work on my car i want to put that on and see if it was just the valve seals
ive just been checking Craigslist...i dont really wanna pay for shipping, im just waiting for somthing to pop up around me, my buddy has a z6 motor, but it needs rings and valves..he wants 200...and my other buddy has a JDM h22 but he wants 600 for motor and an extra 200 for tranny...but its been siting under a tarp for 2 years so im iffy on that
Anything that you buy super cheap will not be the best quality engine. You have to spend money to get something of quality.
For the time being, why don't you get your engine to stop burning oil and then save some more money for a higher quality swap?
Cool Cool Island Breezes. BOY-EE
That engine will cost a good amount to swap in. You'll have to buy mounts, trans, shift linkage, etc.
You could use a D series trans with an adapter...but...then you'd have to buy the adapter.
F series engines mount just like H series engines. The F and H transmissions are also interchangeable.
Don't do it. Buy another D series if you want a cheap swap.
alright sounds good...im just super broke right now so i saw this cheap motor and thought why not...so should i just try to swap the heads and see if that helps?..i mean i can put new seals in and everything caust its not on the car...and wouldnt the 16 vavle give me a lil bit more power?
??? your car comes with a 16 valve unless it's a CX.
You can't use the Accord's F series head on your D series if that's what you're asking.
i have a cx(8valve)..and the guy i got the car from gave me the head cause he blew the head gasket from it over heating, he thought he cracked the head so he oerded this one from ebay saying d15b8 he took the old head to the shop to get checked and it was fine, so he never put the new one on he just replaced the head gasket and put the old one on...he called a honda dealership and they said it would work no problem, its just a 16 valve...im not talking about the acorrd motor anymore...
jining
37
Jul 15, 2009 12:09 AM
