my car just dies randomly
Old May 18, 2009 | 09:31 PM
SRZsmack's Avatar
Default my car just dies randomly
my car has always just died on a random basis when i come to a stop, so far i have changed my distributor cap, rotor, wires and plugs, and ive ran seafoam through it.... is it my coil just stopping? is this common? its really starting to **** me off ...
it also idles REALLY low and it doesnt get any higher the distributor is already adjusted to what should be the highest idle...
Last edited by SRZsmack; May 18, 2009 at 09:33 PM. Reason: mis spelling didnt explain everything
Old May 18, 2009 | 09:37 PM
D16SiHatch's Avatar
Default Re: my car just dies randomly
you adjusted the distributor to try and change your idle? there is a screw on the throttle body to adjust your idle.
Old May 18, 2009 | 09:39 PM
SRZsmack's Avatar
on the throttle body? never seen one. this is mpfi btw.
Old May 18, 2009 | 09:45 PM
D16SiHatch's Avatar
yep its on the tb. use a flathead screwdriver to adjust it. clockwise to lower the idle, ccw to raise it.
Old May 18, 2009 | 09:47 PM
SRZsmack's Avatar
is that on every tb? because mine looks a little different.
Old May 18, 2009 | 09:50 PM
D16SiHatch's Avatar
i want to say its on like all 88-95 mpfi tb's but i'm not absolutely sure of that. do you know what tb you have?
Old May 18, 2009 | 09:52 PM
SRZsmack's Avatar
its the hf model tb and it looks a little different, some of the same characteristics tho ill check tomorrow and thanks.
Old May 18, 2009 | 09:56 PM
D16SiHatch's Avatar
okie doke. let us know what you figure out
SquirtleSquadEf9's Avatar
when ur stoped do ur RPMs go up and down??? does it randomly spike when ur crusin???
Old May 18, 2009 | 09:58 PM
SRZsmack's Avatar
when i slow down to a stop the car just died completley until i let the clutch out to rolling start it back up. it does it when i push the clutch in sometimes too.
Old May 18, 2009 | 10:06 PM
hmmm wierd i would say its ur idle air control motor. but wat the other guy says sounds pretty right. try it
Old May 25, 2009 | 09:25 PM
SRZsmack's Avatar
yeah my idle was just screwed all the way in and it died instead of idling since the idle was too low. i adjusted the idle with the screw he showed me ^ ^ ^ it was located on the top of the TB and now i have no problems with the car dying.. thanks ^_^
Old May 25, 2009 | 09:27 PM
SRZsmack's Avatar
BTW what TB was in that picture?
delsolmaniac
Feb 13, 2011 07:57 PM
JDM H power
Mar 21, 2009 10:15 PM
g0tgot
Feb 1, 2009 07:27 AM
allmotor2.1
Nov 30, 2007 09:14 AM
SwappedLSHatch
Apr 6, 2006 04:33 PM
