EG automatic into EK automatic
I have a 97 sedan that's the wifes, and the auto tranny is shifting all screwed up. It's slow upshifting between gears and slips sometimes. Some solenoid or vacuum valve is probably screwed up. I've pulled the shaft speed sensor plug it seems to shift harder and slips less-to buy me some time...but I have a CEL for it too. Anyway it's the electronic one, and I have a couple of JDM EG auto trannys sitting around. They both have the two solenoids right by the motor serial number area, but the EG version is cable kickdown and void of all the electronic ****. If I installed the EG tranny and left all the extra plugs hang, any reason it wouldn't work?
I realize I will still have the CEL but the engine still rev's normally and is getting 36mpg as is, I just have to drive like grandma or it misshifts and slips.
As you're already aware its gonna throw at least one CEL, maybe a couple, so god knows how its going to work. I can't see it working properly and I can't see it being worth the time and effort to screw around with it to try to make it work, '96 - '00 trannys must be cheap and easy to find by now.
I may have to resort to a used USDM one, but it'd be nice to use the one I have. I much prefer the EG series automatic. Problem is even the JDM EK's still had EG series auto's on the D-series, all the EK engines I imported still have mechanical kickdown cables on them. I'm thinking of unpluging all the wires except the two solenoids and see what happens, if it still works maybe I'll go for it. Otherwise maybe I'll post a wtb ad on here for another one.
"Bacon Tendercrisp chicken, the most powerful sandwich in its class"
Btw I thought that was a funny *** commercial, only ran for a day or two though..
I knew I didn't dream that commercial, up until now no one else seemed to have seen it, I was starting to wonder if I dreamt the whole thing.
EG9turbo
Aug 14, 2008 01:16 PM
red civic standard
Jul 27, 2007 09:54 AM
Campee
Nov 11, 2003 05:12 PM
