new to me 1994 civic ex questions
I really don't know much about hondas. I had one back in the 80's that ran pretty good while I was in high school. I also had one of those really tiny ones with a shifter on the dash that didn't last but a couple of months and blew up. :lol:
I just picked up a 1994 civic ex 5 spd coupe for $2200 to save on gas. It looks pretty good except the paint. I found through the FAQ it is a EJI chasis and has a D16Z6 engine and was made USDM. It doesn't have A/C which seemed wierd for an ex.
What I was interested in learning was what size tires came on it stock, what the weight is, what viscosity oil I'm supposed to use, what is the interval for timing belt replacement, etc. Is there a single source I can go to for this info. The car didn't come with an owners manual. Thanks.
(edited because I screwed up the year, it's a 1994 and a D16Z6 engine USDM)
Cool Cool Island Breezes. BOY-EE
The interval for timing belts is around 100k miles or 7 years. Stock tire size kinda depends on what options the car came with...but it should be either 185/70/14 or 185/65/14 or 195/60/14. You can find out for sure by searching on tirerack.com or discounttire.com or any other tire site that allows you to look up by vehicle.
The curb weight can be found on www.edmunds.com. I would assume around 2300lb. You can also take the weight on the door jamb and subtract all the max front and rear weights from that number (also on the door jamb).
Use 5W-30.
You can find all the info by either buying a used owners manual on eBay or buying a haynes or helms manual.
Use 5W-30.
The acura wheels on it have 195/50/15 (22.7")nitto tires on them. Shorter than the 185/70/14 (24.2"), the 185/65/14 (23.5), and the 195/60/14 (23.2") you mentioned.
I saw this good thread about tires.
2555 lbs is what the weight on the tag reads (front and rear combined)
Thanks for the oil and timing belt help.
is it a vtec? if so you got a very rare engine on your hands look after it. you wont get spec for it like comp ratio Hp etc.... but if you ever need engine parts just say its a D16Z6 since their very much a like
Needs paint( I think all the old ones do), but the interior is near perfect except for the seat fade on the rear seats.
OP: A good tire size would be around 205/50/15. That corresponds almost exactly to the 92-95 OEM tire sizes.
I just picked up a 1992 civic ex 5 spd coupe for $2200 to save on gas. It looks pretty good except the paint. I found through the FAQ it is a EJI chasis and has a D16a engine and was made in Japan. It doesn't have A/C which seemed wierd for an ex.
D16Z6
Found in
1992-1995 Honda Civic Si
1992-1995 Honda Civic EX, EX-V
1992-1995 Honda Civic ESi (European Market)
1993-1995 Honda Del Sol Si (US)
1993-1995 Honda Del Sol ESi (European)
Displacement : 1,590 cc (97 cu in)
Bore and Stroke : 75 mm × 90 mm (3.0 in × 3.5 in)
Rod Length : 137MM
Rod/Stroke : 1.52
Compression : 9.2:1
Power : 125 hp (93.2 kW, 127 ps) @ 6600 rpm
Torque : 106 ft·lb (14.7 kg/m, 144 Nm) @ 5200 rpm
Redline : 7200 rpm
Fuel Cut : 7411 rpm
VTEC Switchover : 5800 rpm
Fuel Control : OBD-1 MPFI
Head Code : P08
ECU Code : P28
from wikipedia
The only 1.6L VTEC available in the U.S. from the factory until 95 was the D16Z6. The B16A came out in 95 in Del Sols.
Your chassis code will be in your VIN. Letters 4 and 5 and number 6.
Your VIN also tells you the country of origin. 1 means U.S. J means Japan. 2 means Canada.
Just to clarify, civic coupes did not exist unitl the 1993 Model Year. You must mean a manufacturing date of 1992. Your documentation and title should not list 1992 as the model year. Also, just an FYI but Civic Coupes were not manufactured in Japan, but rather in Honda's plant in Ohio. I believe all of the coupes were assembled here, even those that were sold in other countries. Don't worry about the faded black paint. Faded roof, trunk, and hood are very common now with these cars. More Importantly, I think, is rust. And you seem to have gotten a rust-free body! Congrats on a great pickup!
Quick question on the wheels on my car. I was told they were off an acura. They are
15x6 wheels the center caps read Acura. I checked the acura wheel page from the faq and it shows only one 4x100 wheel and that is for a 14" wheel. Are the wheels on my car knock offs or something not on the list or do I have a 4x114 bolt pattern? (faq says I have 4x100) Thanks.
I found a link in the faq. It doesn't list 15" for acura but another site did list one that matches. integra acura gsr Fat phat five fives. Thanks for whoever put together the faq.
no. I was referring to 92-95 civics anyway. A lot of Integras are made in Japan...maybe all of them?? Not sure.
95lscivic
Oct 21, 2009 05:22 PM
blkdragn95
Jun 28, 2004 08:43 AM
