help, car has fuel and spark but wont turn over
Old May 18, 2009 | 08:31 AM
stouzey's Avatar
Default help, car has fuel and spark but wont turn over
So here is my dilemma.
Friend and I replace my rotor and cap in my civic which has a OBD1 JDM B16A in it. We had to pull the distributor because the bolt that holds the rotor onto the pin inside the distributor was stuck. Stupid us, we went to remove the pin from the distributor and we never marked which way the key was seated on the end of the pin. So we finally got the new rotor on, put on the key, put on the rotor, put the plug wires on, and go to fire it up, and we notice the distributor is just "wobbling" or rotating as if it was not seated properly. The car would not start. So we pulled the dizzy again, and we thought my timing was out 180degrees so we just span the key and tried again, no go. So we took the key off and flipped it around again, and tried again, to no avail. So we used a compression tester and a vacuum plug to get TDC on cylinder 1 according to this diagram:
We tested using cylinder 1 in that picture, and the rotor was facing cylinder 1 on the distributor. still nothing.
We have checked, we have spark on all 4 cylinders, we have fuel pressure, and my injectors are pulsing. We have whats needed for ignition, yet its not starting.
We checked all fuses, we put on my old rotor/cap and still nothing, it just turns and turns but wont fire.
Any ideas? Anything I forgot?
A friend found this thread on honda-tech and looked and so far what theyve said ive tried and nothing, this is the thread here..
Thanks for the help..
Old May 18, 2009 | 09:13 AM
DCSportEJ1Civic's Avatar
Default Re: help, car has fuel and spark but wont turn over
was the car running before the cap and rotor were replaced?
Old May 18, 2009 | 12:17 PM
stouzey's Avatar
car was running, its all OEM, its a 92 EG6 from japan, stock ecu and stock distributor.
Old May 18, 2009 | 12:53 PM
do you have spark at all?
Old May 18, 2009 | 01:05 PM
stouzey's Avatar
yes, all 4 cylinders have spark, and fuel.
Old May 18, 2009 | 10:47 PM
stouzey's Avatar
bump any input? didnt have a chance to work on it today because i lost my ****ing keys... FML
Old May 18, 2009 | 11:18 PM
92B20VTEC's Avatar
I had this SAME problem with my motor after a re-build. Spark and fuel soaked plugs, turns out the injectors were not firing for the correct cylinders. I took my dizzy off and my fuel rail with injectors off and turned the dizzy by hand to see what injectors were firing. This way I could see the spray from the injectors to be 100% sure, and they were all firing for different cylinders.
Old May 18, 2009 | 11:20 PM
stouzey's Avatar
what would cause that, if you know?
Old May 18, 2009 | 11:28 PM
92B20VTEC's Avatar
well im my case the injector wires were mixed up somehow.
Old May 18, 2009 | 11:30 PM
stouzey's Avatar
mine shouldn't be considering it was fine before, and they weren't touched. its all stock, its a 92 si-r from japan, stock b16a, not swapped.
Old May 18, 2009 | 11:32 PM
92B20VTEC's Avatar
only way to tell is to check. A motor needs spark, compression and fuel in the right order.
Old May 19, 2009 | 05:47 PM
a motor needs Spark, Fuel, Compression, and Timing. given the fact that the ignition system and timing were the two factors that were worked on were Spark and Timing it pretty much narrows it down. and you said it has Spark. if it has fuel and spark the only thing that can be wrong is that you have them at the wrong time. check firing order, check to see if the distributor is 180 out again. check to see if anything was left unplugged, maybe pull the dizzy cap off and check the camshaft position sensor. is it trying to fire at all or completely nothing.
Old May 19, 2009 | 06:31 PM
shailoche's Avatar
+1 for the firing order. I have seen many D's and B's not fire simply because the plug wires were not ordered correctly. Check them again.
Old May 19, 2009 | 06:35 PM
iwanttokillgod's Avatar
you said it wont turn over how do you know it has spark then
Old May 20, 2009 | 09:39 PM
stouzey's Avatar
sorry, it turns over, but wont ignite.
the problem was my timing belt skipped 3 teeth on the intake cam, lucky i have no valve damage.
so its running fine now.
ratchetEDsedan
14
May 30, 2017 07:08 PM
PalmSpringsDelSol
Jan 21, 2008 05:11 PM
integ_lude
10
Oct 1, 2007 04:02 AM
brokenojoke
Mar 20, 2006 02:43 PM
atli126
Oct 19, 2003 11:16 PM
