Timing issue
Old May 18, 2009 | 08:29 AM
dso's Avatar
dso
Icon2 Timing issue
i was just wondering if the timing belt was off two teeth, would i even be able to start my car? or would it start and just hesitate upon acceleration?
Old May 18, 2009 | 08:35 AM
Deathcab's Avatar
Default Re: Timing issue
2 teeth? Eh you may be able to get it running but it would be backfiring and sputtering all over the place and probably would not idle.
Old May 18, 2009 | 08:42 AM
dso's Avatar
dso
would one be less dramatic? i'm only asking cause my mechanic called and told me that when he was replacing the timing belt he saw that it was two off, but that seemed like it would be very noticeable.
Old May 18, 2009 | 12:00 PM
ballinthavx's Avatar
I think i have a similar issue. I think my could be out of timing as well. My car starts just fine but it idles in between 2k and 1.5k when it gets to proper operating temp it still idles high. The car also hesitates (sputters) under acceleration. if you hold the accelerator down long enough it finally clears up and goes but after you switch gears, it just hesitates again. I have new plugs and wires so i know thats not whats causing it.
OGCRV2001
Honda CR-V & Element
18
Feb 12, 2015 11:54 AM
WrenchinRosie
Jan 24, 2015 08:05 AM
k20user
Aug 13, 2010 04:20 PM
boarding2008
Jan 25, 2009 02:06 PM
dreweg
Jul 14, 2003 10:33 AM
