Runnin Hot issues
Old May 18, 2009 | 07:50 AM
SweetDA9_TR's Avatar
Icon3 Runnin Hot issues
so i have this issue, b16 on 5 psi (for now).. i drive a little and and the car runs hot..if i boost the car runs hot a lttle faster...but as soon as i stop temp gauge goes down and is fine...also i can sit still all day long and car wont run hot..new thermo stat..could it be radiator or...sumthin worse??? HELP
Old May 18, 2009 | 12:51 PM
fcm's Avatar
fcm
Old Fart
Default Re: Runnin Hot issues
Does the rad fan come on when engine temp reads hot? 94
Old May 19, 2009 | 05:19 AM
well the rad is hooked to a toggle...but i leave it on
Old May 19, 2009 | 05:39 AM
fcm's Avatar
fcm
Old Fart
Is the rad fan running in the right direction, "pulling" air through the rad? 94
Old May 19, 2009 | 05:42 AM
yea already did that too......
Old May 19, 2009 | 06:11 AM
kyden's Avatar
are you tuned?
Old May 19, 2009 | 05:14 PM
fcm's Avatar
fcm
Old Fart
Stock or aftermarket rad?
If stock, is it a full or 1/2 rad? 94
Old May 19, 2009 | 09:41 PM
Scott_Tucker's Avatar
Its possible the radiator does not have enough capacity to remove the amount of heat that is being produced by the engine.
Old May 20, 2009 | 04:53 AM
yea that is a possibility....i dunno its jus gettin on my nerves so bad now that i dunno wat to do or try...
Old May 20, 2009 | 04:54 AM
o yea FCM is at 1/2 Rad
Old May 20, 2009 | 05:22 AM
fcm's Avatar
fcm
Old Fart
Replace the rad with a full size one, at least double core.
I ran into a guy with a 1.8L LS swap in a CRX using the 1/2 rad last weekend, he was competing in the annual Knox Mountain Hill Climb, on his first pass he crossed the finish line with an overheating engine, that will happen when you drive all out for 2.2 miles up hill 800 feet around 9 corners in under 3 minutes using a1/2 rad and leaving the block plate in place, I suggested he at least remove the block plate to get better air flow over headers and engine, that helped a little but he will be replacing the rad. 94
Old May 20, 2009 | 05:42 AM
fcm wonderful idea..only thing is im boosted and manifold is in the way..thas y i had 2 switch to 1/2 Rad.. ....ne thing else
Old Jun 4, 2009 | 08:48 PM
eastbayg's Avatar
i just bought an aluminum radiator with 33% more capacity than my stock 92 integras and a dual fan set up, upper and lower polished tanks, and tube and fin design. i read reports and feedback on it, it seems like an excellent product with a 3year warranty. the only thing is, its not a major brand name, its made by godspeed. but with a 3 year warranty, its better than koyo and mishimoto. do u think its a good buy? hasnt been delivered yet
Old Jun 4, 2009 | 09:40 PM
locash's Avatar
I'd say its one of two things:
1. The tune. Timing issue perhaps, causing excessive EGT's.
2. Cooling fan problem?
loweredimages
Jun 1, 2014 03:17 PM
Austin184
Dec 21, 2012 09:39 AM
cpierich
Feb 26, 2012 06:27 PM
needaimport
Jul 3, 2005 05:40 AM
mickey513
Mar 18, 2004 06:18 AM
