please help
Old May 18, 2009 | 06:06 AM
jay5555ca's Avatar
New User
Default please help
I took a 92 civic cx engine and put it into a 95 4door se now when I finished I realized that the map sensor was different cause of the wiring so I took the original engine harness from the car and installed it on the older engine . fine and dandy went to start the car and it would not start . it turns over and the fule pump turns on like normal. seems not to be any spark or something . I am totaly stumped I have swaped motors before pluged everything in and no problems . but for some reason this engine wont start . is their anything different with this engine are the sensors wired all the same or do I need to change something . I havent hooked up the rad yet so their is no coolant in the system wil this make the car not start . someone please help me I am ready to burn this car LOL !!!
Old May 18, 2009 | 06:11 AM
Pothole987's Avatar
Default Re: please help
no spark? check the thermostat ground (on the thermostat housing)
Old May 18, 2009 | 06:15 AM
civic_driver's Avatar
You have to use the original map sensor as well, not just the wiring and also, the original ECU.
Old May 18, 2009 | 09:14 AM
jay5555ca's Avatar
New User
I checked and cleaned ground wire on thermostat and I used the new map sesor and ecu still nothing any other things to look at
aaronl29210
Sep 29, 2011 06:00 PM
d15bflat
Jul 7, 2009 12:29 PM
crick_james
Oct 7, 2008 07:57 PM
crxisok
10
Jun 25, 2006 01:22 PM
