p08-1? what head?
Old May 17, 2009 | 12:31 PM
SamN's Avatar
Default p08-1? what head?
My buddy bought a vtec head to put on his y7 block he thought it was a z6 but its stamped p08-1 so I thought it was a jdm d15. However there is no 9/1 marking there is a 9/5 one tho. Any ideas what head this could be?
Old May 17, 2009 | 12:33 PM
SamN's Avatar
Default Re: p08-1? what head?
Also it ran for a few days now it won't start even with a new coil in the dizzy? There's no spark could it just be a bad distributor?
Old May 17, 2009 | 01:14 PM
94EG8's Avatar
Seagull Management
Could be from a D16Z6, JDM D15B Vtec or JDM SOHC Vtec ZC, they're all stamped P08.
Old May 17, 2009 | 01:19 PM
Skadaloz's Avatar
if it ran for a few days and now has no spark...it could b a wiring problem since you put a new coil in the dizzy but it could just b a bad coil, try another dizzy from another car and see if it runs, if not then its a wiring problem
jdm d15b vtec, usdm d16z6, usdm d16y8 heads are all stamped p08
Old May 17, 2009 | 01:28 PM
94EG8's Avatar
Seagull Management
Y8s are stamped P2J.
Old May 17, 2009 | 01:54 PM
mark11017's Avatar
I was getting no spark so i put a new coil in, even with the new coil still not getting spark. Im assuming it needs a new dizzy since the y7 doesn't fit to whatever head is on the car but im not understanding how it ran with the y7 dizzy in the first place..
Old May 17, 2009 | 06:25 PM
Skadaloz's Avatar
sohc non-vtec dizzy can work on sohc vtec head, i know b/c i have used a 0bd1 dx dizzy on my 0bd1 d16z6...so find out if that head is obd1 or 0bd2...since y7 dizzy doesnt fit, try using an obd1 sohc dizzy and go from there
Old May 17, 2009 | 07:14 PM
94EG8's Avatar
Seagull Management
They sort of work, you can get 1 bolt in if I remember correctly, or you can hack the case up and get 2 bolts in. There are 3 different D-series bolt patterns for distributors:
OBD1 non vtec and all OBD2 SOHC D-series engines
OBD1 Vtec/Vtec-e D-series
OBD1 DOHC ZC
Old May 17, 2009 | 07:27 PM
mark11017's Avatar
Yeah you get one bolt in that's about it and u still have to modify it a little bit to get that one bolt in. Im gunan try the z6 diz and go from there hopefully thats the problem. Its deff an obd1 head though i know that much.
Old May 17, 2009 | 07:56 PM
TravisCadello's Avatar
I seen today a head stamped P08-5 on a ZC block. is this a better head than the y8 head?
WhiteyW/AHonda
Sep 11, 2011 04:49 PM
charlieboyhonda
Oct 31, 2007 06:33 AM
b20accord
Dec 8, 2006 11:21 AM
HTn00b
16
Nov 14, 2006 09:39 AM
@irborne
Apr 23, 2003 09:07 AM
