95 gsr into 96ek needs wiring help
Old May 16, 2009 | 06:26 PM
TerpPL908's Avatar
Icon2 95 gsr into 96ek needs wiring help
95 gsr (obd1) was swapped into my 96 ek (obd2), got a p72 ecu with the jumper harness. Need help wiring the obd2 harness onto the gsr. I know i got the injectors spliced in right some of the sensors plugged right up, the alternator and distributor dont match up. Im stuck, wire colors are faded on some components, and pepboys manual only helped so mutch.
Old May 16, 2009 | 06:44 PM
ekb16's Avatar
Default Re: 95 gsr into 96ek needs wiring help
u can change the alt and dizzy to match the harness u are using
Old May 16, 2009 | 07:24 PM
TerpPL908's Avatar
the dist. from the sohc wont fit and the alt is not working
Old May 16, 2009 | 07:58 PM
ekb16's Avatar
get urself a dohc vtec dizzy and alt for whichever harness ur using
Old May 17, 2009 | 12:18 PM
TerpPL908's Avatar
do u know how much is a s1 cable trans worth?
Old May 17, 2009 | 08:04 PM
xddrfr3akx's Avatar
A new dizzy is expensive passwordjdm sells a nice conversion harness for 0bd1 - obd2a its like 40 shipped.
Old May 17, 2009 | 08:31 PM
jmorales1811's Avatar
get the alt and dizzy of the 99-00 civic si
Old May 20, 2009 | 08:56 PM
TerpPL908's Avatar
do i hook up the v tech,oil pre.,knock, to the ecu pin or the conv. harness?
Old May 21, 2009 | 05:57 AM
RyanA's Avatar
Swap the internals from your cars original dizzy into the B dizzy. Everything goes right in. There, you now have a dizzy with correct plug for no money out of pocket.
For alt, just get one that is correct.
Old May 21, 2009 | 07:42 AM
redlinetuning's Avatar
wire things up to the conversion harness to make things easy.
Old May 23, 2009 | 07:09 AM
TerpPL908's Avatar
Icon2 Re: 95 gsr into 96ek needs wiring help
hey so my swap is finaly done, BUT it don't start, the back up light is ok, i hear the relay, but i think my problem is the 2 sensors on the clutch pedal, how and where do i hook them up, i got the pedal from a junk yard and the wirtes r missing, one of the switches has 2 pins and white housing, the other has 2 pins yellow housing and a black wire and a blue wire, i need to drive today can any1 help
Old May 23, 2009 | 05:02 PM
TerpPL908's Avatar
ok so i got the motor to turn over but its not starting i got spark i got air and i need fuel, i didnt hear the main relay click. no noise from the fuel pump, is it posibele for the relay to go bad during the swap?? also mu viper alarm is 3/4 wired up, i didnt finish yet, can that have some effect on it???
ej6tjs
Jun 21, 2010 06:05 PM
snowpro127
Northeast (Sales)
Jun 2, 2008 12:07 PM
MidShipCivic
28
Sep 19, 2007 10:01 PM
B18CYAAA
Jul 16, 2007 03:59 PM
swatteamtimmah
Oct 1, 2006 06:30 PM
