Removing side moldings
Old May 16, 2009 | 12:46 PM
Eighty-Nyne's Avatar
Default Removing side moldings
Simple question..I searched and didn't find anything.
HOW THE FUDGE do you get these pitas off.
Old May 16, 2009 | 12:59 PM
Jwbetley's Avatar
Default Re: Removing side moldings
Open the door. Look right near the rubber trim by the latch. Find and remove the 10mm plastic nut. Gently pull the trim out to clear the screw part from the door. Slide the trim peice towards the front of the car. You may need to slide it pretty hard. This will release the front clip. Now gently lift the front of the trim along with the rear of the trim and slide the trim to the back of the car. Just finagle it a bit and it will come off. The fender trims are a bitch and usually require the fender to come off. If its a sedan or wagon, the tiny rear trims can be taken out by breaking the back clips and just replaceing them with small screws. Good Luck
Old May 16, 2009 | 04:49 PM
dacrxguy's Avatar
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/diy-how-remove-side-moldings-2482205/
Old May 16, 2009 | 05:40 PM
jhammond_82's Avatar
Reject Papi
yeah, they do suck. lol.
avstar26
Apr 22, 2009 10:28 AM
mxl360
Mar 8, 2009 04:49 PM
Weapon
Jun 18, 2004 01:38 PM
Black93DelSolSi
12
May 9, 2003 06:07 AM
DSC
Mar 4, 2002 08:34 AM
