Motor mounts for a GSR into an EK
Old May 16, 2009 | 11:30 AM
ViSiONxBoY's Avatar
Default Motor mounts for a GSR into an EK
Just a few questions, swapping a 96 GSR into a 96 EK, so I'm lookin' for motor mounts.
Are Integra B series motor mounts the same as EK B series motor mounts? If not are any of them interchangeable?
I already have the rear mount, I just need the upper tranny and upper driverside. Theres a guy selling B16 motor mounts from an Integra and claims they are interchangeable to an EK. Is it true?
I'm only lookin' for OEM mounts due to insufficient funds, I cannot afford Innovative/Hasport mounts like many other's are just plainly suggesting.
Old May 16, 2009 | 11:31 AM
ViSiONxBoY's Avatar
Default Re: Motor mounts for a GSR into an EK
Thanks in advance.
Old May 16, 2009 | 11:39 AM
98civdx's Avatar
Master Detailer
im not 100% on the integra mounts for the ek but i dont think they will
find some oem 99-00 civic si mounts they will fit for sure.
Old May 16, 2009 | 11:47 AM
ekb16's Avatar
first u need the right mount brackets..99-00 Si rear L bracket and 99-00 Si timing belt side mount bracket (2 long studs)
Old May 16, 2009 | 12:25 PM
GMOE's Avatar
-99 civic si rear engine bracket
honda pn#-50827-S04-N10
-96-00 Civic(all models) manual upper tranny bracket
-96-00 Civic(all models) driver side upper engine bracket
-99-00 Civic si driver side engine mount(2 bolt pattern mount bolted on block behind timing cover) honda pn#-11910-P30-000
-94-01 integra or 99-00 civic si manual passenger side transmission vibration mount(3 bolt pattern)
-94-01 Integra driver side block vibration mount(4 bolt pattern, ac comp mounts to this mount)
Hope this helps
Old May 16, 2009 | 01:38 PM
ViSiONxBoY's Avatar
Hope this helps
So you're saying I can use my stock D series upper transmission and upper driverside mounts? Assuming so since it says all models.
And the vibration mounts are also known as lower mounts correct?
So I guess all I have to worry about is the 99-00 Si timing belt cover mount.
Old May 16, 2009 | 02:14 PM
GMOE's Avatar
D series upper trans mount will work(manual trans only)
D series upper drive side mount bracket will work(its the 3 hole bracket that mount to the rubber tripod mount already on the car)
Usually the hard one to find on the street is the 99-00 civic si mount behind the tb cover.
PN# 11910-P30-000
its about $49 new on www.hondapartscheap.com
They new oem parts and its the cheapest place I found so far online for oem parts, copy and past the pn# I gave you and goto the site, it'll show to the pics so you have an idea what it looks like.
Old May 16, 2009 | 02:16 PM
GMOE's Avatar
Heres the link for the pic
http://www.hondapartscheap.com/south...t=0&quantity=0
Old May 16, 2009 | 02:21 PM
GMOE's Avatar
Forgot, yea the vibration are lower mounts, their 2 pieces, one is rubber which bolts to the frame and the other to the tranny(and block for the otherside), the rubber portion you can use any 96-00 civic and the mount portion is listed previously
Old May 16, 2009 | 07:01 PM
ViSiONxBoY's Avatar
Perfect thanks bro
Old May 17, 2009 | 03:07 PM
runwitme's Avatar
all these parts would be the same for a 96 LS into a 96 hB dx . correct?
Old May 17, 2009 | 03:09 PM
GMOE's Avatar
Hope this helps
Old May 17, 2009 | 03:15 PM
runwitme's Avatar
ok thx
Old Aug 5, 2009 | 11:12 PM
tysonboy's Avatar
great info
Old Aug 6, 2009 | 02:44 AM
EKSiR99's Avatar
yeah nice info
Old Aug 6, 2009 | 08:04 AM
ltrkstr2k's Avatar
This will work for all Bseries swaps into any 96-00 Civic
Old Aug 7, 2009 | 06:52 PM
ltrkstr2k's Avatar
anybody ever try using a Gsr block mount? instead of having the 2 studs it has 3. i wonder if it would make the engine sit differently.
Old Aug 7, 2009 | 07:28 PM
-__-'s Avatar
^^ dont think that one will work..it might tweak the motor out of place.
BUT are u planning on keeping ur A/C?
in that case u need a CRV A/C bracket.
Your D-Series A/C Compressor bolts right onto it. also for power steering, if u have a 99GSR pump u can re-use ur D-series stuff
Old Aug 8, 2009 | 04:36 AM
ltrkstr2k's Avatar
I'm already swapped I just have 2 gsr block mounts laying around lol
Old Aug 8, 2009 | 04:37 AM
vgalione's Avatar
stock mounts should work fine
Civic082382
Nov 19, 2009 12:22 PM
rick_rabies
18
Jun 1, 2009 10:53 AM
HB VTEC
Nov 24, 2006 07:40 AM
crazykid9137
Jul 22, 2005 11:35 PM
electric-boost
May 10, 2004 06:57 PM
