Correct firing order with pics for obd1 b series in a eg coupe? Need pics to know
Old May 16, 2009 | 09:27 AM
80 dolla crx hf's Avatar
Default Correct firing order with pics for obd1 b series in a eg coupe? Need pics to know
I cant figure out the firing order starting from the dizzy side
The haynes book sucks and just tells the firing order it does not show a pic to make sure you have it right
Need to know what cylinder goes where
top left
top right
bottom left
bottom right
Old May 16, 2009 | 09:52 AM
Former User's Avatar
Default Re: Correct firing order with pics for obd1 b series in a eg coupe? Need pics to know
Cylinders order is 4-3-2-1 from distributor to timing belt:
Old May 16, 2009 | 09:53 AM
GsrHatcher's Avatar
bottom left-1 top left-3 top right-4 bottom right-2
Old May 16, 2009 | 10:27 AM
I have it like that ands its still not starting timing is dead on it gets spark, compression and fuel it just turns over....
Old May 16, 2009 | 10:31 AM
Is the CEL ON?
Are the fuel injector connectors installed in the wrong order?
Is spark bright white/bluish or weak orange?
Were any sensor connectors swapped?
Old May 16, 2009 | 10:33 AM
Slo_RSX's Avatar
Did you replace anything on your car when you took the wires off? ex. distributor?
thats the same siring order for a dseries i have a b not d
Old May 16, 2009 | 10:37 AM
It's the same.
Do you measure battery voltage at the connector of each fuel injector?
Old May 16, 2009 | 12:33 PM
Originally Posted by RonJ@HT
Is the CEL ON?
no pretty sure they are not as the stock harness uncut still in the wire loom would not let you mix them up
bright white
no just the problem using a 2g si/ex manual harness on a b18
Fried one ecu mixing the iat and the egr wire but nothing else is wrong
Nope came runing before i got it of the donor dc
It's the same.
nope but what should the ohm reading be between?
Old May 16, 2009 | 12:37 PM
If you don't measure battery voltage at the YEL/BLK wire terminal of each fuel injector connector with the key turned to ON(II), then you have found the problem.
Is fuse 31 under the hood blown?
96accordsir
Jan 30, 2009 12:55 PM
wm5holla
Aug 3, 2003 10:08 AM
9500rpm
Sep 29, 2002 03:21 PM
