No Start
Old May 16, 2009 | 07:18 AM
mikehawk's Avatar
Default No Start
94 del sol .. having problems every once and a while starting ... mostly mornings .. until 2 days ago it won't fire at all .. motor turns over gas in the tank
Tried replacing main relay with no results.. it was a used one so idk if maybe that one is bad too.. other suggestions have been made ..
ECU
Fuel Pump
any other suggestions .. GO!
Old May 16, 2009 | 08:10 AM
Master23's Avatar
Default Re: No Start
Check out this starter troubleshooting guide:
http://www.garage411.com/Starter
Old May 16, 2009 | 08:15 AM
mikehawk's Avatar
its turns over but the fuel pump isnt priming
Old May 16, 2009 | 09:36 AM
hannslebo's Avatar
bad rotor in distributor??? my friend had the same problem on his TEG and he changed his rotor and has not had trouble since.
Old May 16, 2009 | 09:50 AM
Former User's Avatar
The different fuses power the main relay. Check whether fuse 31 (hood) or fuses 18 or 24 (dash) are blown.
Old May 16, 2009 | 02:06 PM
green99civic's Avatar
Check your fuel pump fuses
Old May 16, 2009 | 04:11 PM
mikehawk's Avatar
ecu ftl
ScottE
Aug 6, 2015 06:19 AM
UniqueX707
Aug 8, 2012 12:21 PM
Coltmorris
Sep 11, 2009 12:51 PM
thebleek
Sep 10, 2008 03:31 PM
wankerman28
Aug 26, 2007 01:04 AM
