changed main relay, pump still wont prime! WTF
ok so when i go to start my car i usually hear the fuel pump prime. well it stopped working. so i thought it would be the main relay. I changed out the main relay and i still have the same problem. my car wont start, my fuel pump wont prime, so wtf do i do.
Re: changed main relay, pump still wont prime! WTF (dumafit)
You should have done some troubleshooting first before you buy/swap parts. Do you get 12V to the fuel pump connector, do you hear the main relay click, did you check the fuses, do you get 12V AT the main relay???
Re: (Relic1)
i did diagnose before i bought items....
ecu fuse under hood is fine.
the ground that connects to the thermostat housing is all good and tight
i have a y7 and y8 ecu so i swapped them and they both do the same thing
my mechanic thought the pump was bad before, but it ended up being that thermostat housing ground. everything was working fine a few days ago and it just seems this happened out of no where. i wasnt driving the car or anything
Re: (sicones)
ok so anyone correct me if im wrong...
but when you turn your key to ON you should hear a click from the main relay,
then you turn your key to start you should hear another click right?
well i dont hear the first click, but when i turn it to start i can feel the click thru the relay.
i have two relays and they both do the same, one is brand new
Re: (thebleek)
Actually this procedure is just to test the relay, you need to test the car.....but use it to see if you are getting the correct voltages and grounds using a meter...
Re: (thebleek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones »</TD></TR><TR><TD CLASS="quote">did you check the fuses</TD></TR></TABLE>
slowpokecivic
07-26-2012 07:37 PM
