FS: MSD 7562 Boost Controller
Old May 15, 2009 | 09:57 PM
mmonday's Avatar
Default FS: MSD 7562 Boost Controller
$250 shipped
brand new...only opened the box to make sure it was all there.
for those that dont know about this boost controller, here is what MSD says about it.
"This stand alone microprocessor boost controller is exactly what-over-the-top turbo powered cars need. This Control uses an extremely fast microcontroller to control boost pressure via an electronically operated waste gate valve.
Through easy to use Pro-Data+ software, you can control the amount of boost pressure used during the burnout and map a boost curve based on time for the launch (up to 12.5 seconds). Control over the boost pressure is achieved through a PWM output that controls a three way electrically operated air valve that is installed between the turbo and the waste gate actuator. (This can also be programmed to your particular actuator.) To help in setting up and tuning the Controller, there is also an acquisition file that records the engine rpm, manifold pressure and the pulse width modulator output. After a pass you can save and download the file to review each pass."
jegs- http://www.jegs.com/i/MSD/121/7562/10002/-1?CT=999
GM used these for years in there pro-fwd cars. feel free to ask any questions, thanks.
$250 shipped
for quickest response please e-mail me.... neon95acr@yahoo.com
Old May 16, 2009 | 02:35 PM
mmonday's Avatar
Default Re: FS: MSD 7562 Boost Controller
bump! open to offers.
Old May 17, 2009 | 02:48 PM
mmonday's Avatar
bump! lower price $275
Old May 18, 2009 | 06:56 AM
mmonday's Avatar
bump! $250
Old May 18, 2009 | 09:42 PM
mmonday's Avatar
bump?
Old May 20, 2009 | 04:30 PM
mmonday's Avatar
final price....$220 shipped.
if i cant get that, then its just going to collect dust.
Old May 21, 2009 | 11:20 AM
mmonday's Avatar
bump
Old May 21, 2009 | 08:25 PM
mmonday's Avatar
final bump.
calib17a
Feb 12, 2007 05:25 PM
Jared
Apr 25, 2005 04:16 PM
Sketch_hs
Aug 10, 2004 09:06 PM
b18bturbo
May 7, 2004 10:17 AM
